Regarding my daily driver... 86 2WD LE 317,000 miles. Day before yesterday... daytime, I turned my headlights on in a construction zone (law here in PA). I saw the blue high beam indicator was lit on the dash. When I tried to kick the high beams down the indicator stayed lit regardless of the stick position. When I arrived at my destination, I got out to check the lights. I expected to see the high beams on all the time. Not the case... I had no headlights at all.
I drove home in the dark. The driving lights were adequate at times and I supplemented by holding back on the stick and lighting all the headlights. All lights worked that way. At some point after holding back on the stick for a few minutes I let up for an on coming car. The indicator light went out and the lights began to function normally. Last night however I saw the indicator blink on for a second and the lights blink off.
Any thoughts on what to replace... and /or an order if I should replace multiple parts. I have trouble fixing things that don't show symptoms or are intermittent at best.
Thanks in advance for your time and attention.
-Jim
