Results 1 to 4 of 4
Thread: Pitman arm
    1984 Toyota Van LE
    Nov 2014
    Evanston, WY
    Question Pitman arm
    I need a new pitman arm for my 1984 Toyota Van LE (power steering)
    I also have a mechanic who will let me find my own parts.
    What keywords should I be searching for? Is the pitman arm also called something else? Or is the idler arm something else completely?
    I found this: http://www.toyotaoempartsworld.com/p...&siteid=215233
    85 2wd 894wd
    Nov 2014
    duncan bc canada
    Re: Pitman arm
    http://www.answerbag.com/q_view/531448 Hopefully you don't need the center steering control arm.......it is an L shaped piece with a knuckle at one end
    1984 Toyota Van 2WD
    May 2014
    New York
    Re: Pitman arm
    Quote Originally Posted by '84LeVan View Post
    Below your feet under the front of the van is the steering gear housing. The pitman arm is attached to that. It is a short link attached to the steering gear housing with a large nut.
    At the other end of the pitman arm is a short drag link (short bar with grease fittings at each end 90 degrees to one another) that connects to a Y-shaped "center arm".
    If the pitman arm cracked I believe you can get one from a salvage yard. Or they are apparently still available:
    http://www.villagetoyotaparts.com/pr...541128040.html
    But you had better cross reference it with your VIN number.
    If there is a leak in the housing, you can get the seal:
    http://www.rockauto.com/catalog/more...969&cc=1279694
    John
    1984 Toyota Van LE
    Nov 2014
    Evanston, WY
    Re: Pitman arm
    Thank you! I'll be sure to ask in more detail what it is that needs to be fixed/replaced so I can make sure I'm purchasing what is actually needed. Your input is valued!
