Hi!
I noticed that some warning lights don't light at startup. I checked all light by removing the cluster and all lights works. The discharge light (battery symbol) and radiator light are the 2 faulty.
Does anyone have an idea what's wrong with these 2 warning lights? What is the component who control theses warnings lights at startup? (they supposed to be on for 4 to 8 second i think)
For the radiator light, i tested the warning switch, the bulb, everything is fine expect the light don't light at startup...
same thing with the discharge warning light (battery). The repair manual say the IC from the alternator could be the problem, but i checked the charging system and everything look good.
Any idea?
Jerome
