Results 1 to 18 of 18
Thread: 4WD rear shocks
    89' TownAce Auto 87' 4x4 5spd LE 87’ 4x4 5spd Cargo
    SEATTLE, WA
    4WD rear shocks
    I know that the OE rear shocks are NLA, but I was wondering which OE type shocks are used for the rear with coil springs. I tried the search function but haven't come up with much as far as after market OE style that's being used.
    I've come up with 2 different type of KYB rear shocks so far-
    KYB -343140-excel-g-shock-absorber
    these are readily available
    KYB -kg4644a-gas-a-just-shock-absorber
    these are out of stock on the KYB website
    I have the front OEM shocks I just got from Toyota but just trying to figure out which rear shocks everyone else has had good experience with.
    Thank you for your input
    Re: OE rear shocks
    Best shock length will vary depending on whether you have stock ride height or if it's been lifted. If lifted, knowing how much will be helpful in determining length. Tim
    SEATTLE, WA
    Re: OE rear shocks
    I'm trying to keep it all stock, I'm pretty sure there hasn't been any modifications done to the suspension, but to be sure I'll have it looked at next time I take it in not unless there's some specific markings on the OEM shocks that I can look at myself.
    Thank you Tim
    Re: OE rear shocks
    The 2 you mention are both well suited for stock ride height. The 343140 is a GR2 shock and the kg4644a is a Gas-a-just. Gas-a-Just shocks are mono-tube and the GR2 is a twin tube design. Mono-tube is a superior design, so IMO these would work better (if you can find them). They will also be more expensive. Tim
    SEATTLE, WA
    Re: OE rear shocks
    Nice thank you Tim that's the confirmation I was looking for, thank you sharing the link. I think I'll go with the KYB KG4644A's
    thank you!!
    SEATTLE, WA
    Re: OE rear shocks
    Niiiiice, I ordered them this morning at 500am and got the confirmation at 600am that they were being shipped out. They should be here next week, I'll give an update when they get here.
    SEATTLE, WA
    Re: OE rear shocks
    I got the KYB's awhile ago along with OEM front shocks. The parts guy told me there were only 4 left (front) and after that they would be NLA. Check it out-
    1987 4WD 5-Speed Cargo (uncut) 1987 4wd Auto Cargo Conversion
    Nov 2010
    Mammoth Lakes, CA
    Rear Shock Part #?
    Does anybody remember which rear Tacoma Shocks works best with the Mr. Gasket spacers? Or maybe point me to the thread?
    Re: Rear Shock Part #?
    I typed "Tacoma Shocks" in the search box and this popped-up: http://www.toyotavantech.com/forum/s...ires-and-power
    Good luck verifying part number though. I scanned the 1st page and didn't find any obvious part number verification. Good luck. Tim
    88 4x4 5 speed
    Feb 2015
    Co
    I have a set of bilstiens I have yet to install, I can get a part number off themy if you need it still. Can't confirm they will work but came from a van guy that said they were the ones
  12. 12-18-2015, 01:47 AM
    Reason
    now a circular link!
  13. #12
    88 4WD 5Spd LE Lifted 2" with Tracker aluminum 15" wheels and 215/75/15 tires 95 4Runner 00 4Runner 3in lift 84 Extra Cab 4WD Pickup 4.5 in lift 79 Supra with 70,000 miles 86 MR2 with a V6 5speed swa
    Aug 2014
    Dillsburg, Pa
    I had purchased rear shock extenders from Toytec and they worked great. They have them in 10 x 1.50 and 10 x 1.25. $19 for 2. I purchased kyb rear shocks and added the 10 x 1.25 extenders and they are great. I also purchased 2" 96-02 4runner rear coil spacers and they worked great as well. I feel a steel or aluminum spacer is much safer than 2 rubber spacers, especially one on top AND bottom.
  14. #13
    '88 4x4 5 speed manual
    Dec 2018
    ME
    Re: 4WD rear shocks
    Looking for rear shock part # recommendations. I like the look of the Bilsteins shown in the Front Shock thread.
    Mine has a 2" lift . -pics with current shocks below.
    When I google the part # on current shocks (48530 ad051) I get no hits except used. Looking or new replacement or better.
  15. #14
    Apr 2015
    wherethevanisrare. FL
    Re: 4WD rear shocks
    You will need to mod the bottom bushing slightly. Google search this site for more.
    LG.
  16. #15
    Dec 2018
    ME
    Re: 4WD rear shocks
    got it. 24-186056 must be the replacement part number (?) When I use advanced search I only get 1 hit which shows a spring mod as well.. Hmm.
  17. #16
    Apr 2015
    Re: 4WD rear shocks
    These are replacement parts for the Tacoma. They will fit fine without mod on a lifted Van. It is the front one (Dacota's) that need some adjustment, My bad!
    Google " lift kit ToyataVanTech" there is a lot more info on this site or use "tags" in the advance search, Gwen just spent a huge amount of time organizing all that, it works.
    LG.
  18. #17
    Dec 2018
    ME
    Re: 4WD rear shocks
    Yes I read through that one a couple times - solid.
    Just ordered - thanks!
  19. #18
    89 Townace 2CT 4wd 88 Vanwagon Auto 4WD
    May 2013
    ATX
    Re: 4WD rear shocks
    Whats the OEM app for the Bilstiens? Tacoma of some sort?
