Transfer case?
I'm looking at a 1993 Previa all-trac automatic. The transfer case needs to be replaced. I read somewhere that the transmission has to be taken out with it. Is that true?
Re: Transfer case?
It's been awhile since i dropped an auto tranny, but I think you can get away without removing the whole transmission. It will be hard to get to the bolts holding transfer to transmission on top and you probably will need to undo the trans mounts to allow the whole trans to drop a bit.
Depending on where you are, if you need a transfer case, I have a 94, removed at 140,000K around 1 1/2 years ago, was working just fine at the time. Edit: Oh, new hampshire, well shipping would probably make it not worth it.
