Page 5 of 5 FirstFirst 12345
Results 81 to 91 of 91
  1. #81
    Van Fan bushcat's Avatar
    '85 Toyota 2WD Cargo Van ------------------ ‘84 Toyota LE Van ————————
    Dec 2017
    Benicia, CA
    Lightbulb Re: Basic Van knowledge for new owners
    I just bought an '85 Toyota Van, 194K miles. It has no service records, previous owner bought it from someone who had a folder of records which he didn't deem necessary to keep. He told me the seals were done by PO and that he kept up on oil changes while he owned it but otherwise has done zero work. Can I trust him? Who knows, but it drove back to my house just fine. One thing I know from my research on here, it needs a new thermostat.
    1. Oil change (10w30)
    2. I'm going to replace the thermostat (with an OEM) one and maybe an aftermarket gasket.
    3. Flush the radiator - never done this before but I want to remove any blockages.
    4. Going to inspect the hoses and see if they need replacing, anybody have a good active source?
    What else should I do as a new owner of a van with 194k miles that has zero maintenance records?
    I'm putting this here because I barely have basic van knowledge and I'm not sure what needs to be done. I can delete/move to appropriate thread if this isn't fitting.
  2. #82
    Dec 2017
    Benicia, CA
    It's mentioned to buy the largest battery possible. What is the largest battery that will fit? I have a 1985. Thanks!
  3. #83
    1989 cargo conversion
    Dec 2016
    portland
    I just did this: group 27 was perfect fit. You'll need to fashion a new strap down for bigger battery
  4. #84
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Always best to replace those washers, but they can be reused in a pinch. Just make sure to check for leaks before putting the engine cover back on. I know the OE Toyota filters come with new copper washers, but not sure about aftermarket ones. You can always buy new copper washers as they should be available at any auto parts store. Just take an old washer and/or your banjo bolt down to help them match it up. Tim
    Also, if you have a butane torch handy, I find it best to anneal them also. Heating up the old copper washers expands them so they will crush when re-used.
  5. #85
    1987 4WD Automatic
    On the outskirts of Mordor
    I have had good luck with this battery as well.
    Napa Legend #7527 Group: 27
    1000 cranking amps
    810 cold cranking amps
    You will need some nylon straps to lower it in/pull it out of the battery bay.
  6. 09-20-2018, 01:24 PM
    Reason
    no longer relevant
  7. 09-23-2018, 03:51 AM
    Reason
    no longer relevant
  8. 09-23-2018, 07:02 PM
    Reason
    no longer relevant
  9. 09-23-2018, 10:00 PM
    Reason
    no longer relevant
  10. 09-24-2018, 02:47 AM
    Reason
    no longer relevant
  11. 09-24-2018, 10:54 AM
    Reason
    no longer relevant
  12. 09-24-2018, 12:39 PM
    Reason
    no longer relevant
  13. #86
    1988 Toyota van LE
    Mar 2019
    Vancouver
    My service manual makes no mention of how to drain the power steering reservoir, only how to top it up. Is this simply unnecessary? I have been draining and replacing fluids one by one and figured this is something I should do eventually.
  14. #87
    I usually pull the pressure feed line off the rack, put it in a jug, start the engine, and let it dump into the jug. I am in WA state though, and they don't salt the roads (undercarriages here are relitively rust free). If you have a rusty one, then I probably would avoid trying to remove. If you do remove, I'd recommend using a quality tubing wrench. Here's a link to a thread where this has been discussed: https://www.toyotavantech.com/forum/...g-system-noise. Tim
  15. #88
    1988 Toyota van LE
    Mar 2019
    Vancouver
    Thanks Tim! I'm in BC so this should be a viable option for me. Cheers!
  16. #89
    Forum Newbie HI_Beach_Van's Avatar
    A June 1989 Toyota Van DX Purchased in Aug 2017, it had 89,000 original miles!!
    Sep 2017
    Oahu, HI
    Once it's back in the hole, try to set it back to the same spot it was before. Next hook up a timing light, put a jumper wire into the "check engine connector", start engine and check timing. Use the service manual for more specific instruction. Here's a link to the PDF download: http://www51.zippyshare.com/v/19640361/file.html
    Good info here, when I clicked the link for the pdf and whispered to myself *please work, please still be there* once the page loaded it said the pdf expired. Do you still have the pdf somewhere to access? Thanks.
  17. #90
    Quote Originally Posted by HI_Beach_Van View Post
    That's a bummer. The file is too big for most email programs to handle so not sure what to tell you. In the past I have tried emailing, and although my business account can handle the size the recipients email usually cannot. I also have an 89 FSM in PDF, but I have nowhere to host it. There's a slight concern regarding copyright, or we would host it here.
  18. #91
    4x4 Cargo
    Cedar City, UT
    you can access the manual on my website under the resources page
