Results 21 to 37 of 37
Thread: Another rough idle question
    1986 LE
    Aug 2017
    Florida
    Re: Another rough idle question
    Yea, I did it a while ago, before I relocated it back to its home.
    However it seems to work fine. When cold she will race north of 1200RPM then settle down to idle. The problem is in this early stage of warm up the idle after the valve closes almost stalls. Again, if I feather it she will hang until another 5 minutes. Then she is OK, but after another say 20 highway driving she will race at 1500 at idle. Then start it again 10 minutes later and she idles very low and shakes. So that is the delta, from almost stall to 1500RpM. If I leave along too long she will eventfully stall. Go figure.
    I will try the pitch test again just to make sure I have it all covered.
    Thank Tim
    1986 LE
    Aug 2017
    Florida
    OK, moving forward on my idle issues. Ready to remove the throttle body. Does anyone know where one can find a gasket for it? I hunted around Rock and others and could not find it anywhere.
    If you're pulling the throttle body take a look at THIS THREAD. The Toyota part number for that gasket is at the bottom of the 1st post. Last time I needed one Toyota still had them. Good luck . Tim
    1986 LE
    Aug 2017
    Florida
    Hey Tim:
    Thanks. I must have looked through this thread 50 times and I missed it.
    I found one on amazon but paid $15 bucks for it
    Thanks again.
    I did do some more trouble shooting prior to the throttle body work. I ran some volt meters on all the VSV's. The ISV was one in question. Turns out I am seeing no voltage going to this VSV when monitored under every condition. There is no real explanation of what this does but it is part of the vacuum system on the throttle body. I will look closer this weekend before I pull the throttle body off.
    Should be fun!
    1986 LE
    Aug 2017
    Florida
    Getting ready to pull the throttle body off I lose one cylinder again for the third time. So off comes the intake to get them out and sure enough it is what I now call " The Injector of Death". Thought Tim would like that one. But really this is a joke. So I am making ready to do the filter mod. Here is shot of the dirty injector. I also found this thing on the driver side of the intake with a little tube on it. Anyone know what it is? I will continue to dig through threads and stuff to define this.
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Pretty sure thats just a vacuum filter...
    Theres a diagram in this pot that shows that item:
    https://www.toyotavantech.com/forum/...=vacuum+switch
    1986 LE
    Aug 2017
    Florida
    Fantastic Tim:
    Wow, this is a nice diagram to boot. But it explains so much.
    OK, on my way to new fuel filters.
    1986 LE
    Aug 2017
    Florida
    Ouch: Just spotted the link was sent by Flecker. Thank you.
    1986 LE
    Aug 2017
    Florida
    Pulled my injectors out and although #3 is full of rust, 1,2 ,4 are not very pretty either.
    Can somebody provide the contact info for Dr Injector? These injectors have less than 5K miles on them, so I think if I get them checked and repaired I will be in good shape.
    Just do a Google search for "injector ultrasonic cleaning Florida (your city)". I'd do it for you, but don't know your city. Tim
    1986 LE
    Aug 2017
    Florida
    Tim:
    Got it!
    Thanks a bunch.
    88 4wd
    Apr 2017
    Oakland
    Hey Tim:
    Thanks again.
    Should be fun!
    Hi there - got a link to the gasket on amazon? All the ones I'm seeing are discontinued... :/
    Just had this conversation on another thread:
    88 4wd
    Apr 2017
    Oakland
    Thumbs up Re: Another rough idle question
    Thank you!
  15. #35
    1986 LE
    Aug 2017
    Florida
    Found the source of the rust getting to Cyl #3. After removing the stock filter , that had 3000 miles on it, looked like it was throwing up blood from its input side. All over the bench, clothes, papers, you get the idea. Was a short walk to pulling the tank. I thought I had already confirmed it was not the tank but when I removed the fuel pump and dropped an LED super bright down there the story was told. Especially on the ceiling of the tank. It was caked with rust and it was falling from the none fuel touching areas.
    So brought the tank to a radiator shop that had some experience with this. They cut a hole in the bottom and treated it with chemicals and power washed. It is about 95% better now. Very little left up there. So she goes back in today.
    I figured the fuel damper, since it is the firs thing that gets hit as the fuel comes from the tank, should be replaced. However when received from RockAuto (Standard Motor FPD3) it would not thread into the fuel rail. It goes about a turn and a half and gets stuck. The old one looks the same. So not sure what to do. It seems like this is the only one that can replace the 23270 Part Toyota calls out for.
    Anyone have any other replacements or should I just try to flush the old one out and use it?
  16. #36
    1988 4WD LE auto dual range t-case 1988 4WD LE auto(the donut van)
    Have a look at this.
  17. #37
    1986 LE
    Aug 2017
    Florida
    Fantastic!
    I will get it and dye it.
