can someone please help me with tires sizes for 15" wheels !?
so...I am number dumb. and can never figure out how tire sizes work. I just spent the last hour and a half doing incorrect math trying to figure out what size tires I should put on for 15" wheels. I found wheels that fit. they are 15x7 and offset is pretty close to the stock 14 inch wheels. and I tested them and they don't rub. Its a 2wd, so I don't want crazy huge tires. just the same tire diameter with a bigger wheel inside. stock tires are 195/75-14. I was thinking 205/60/15? but I really have no clue what I'm doing. so any advice would be great. please chime in if you have put 15" wheels on a 2wd TV. or know tire sizes. trying to get some better rubber for the summer. thanks guys!
Administrator
- 10
Re: can someone please help me with tires sizes for 15" wheels !?
Check this out it might help-
25" Tire Diameter
195/75R14 = 25.5x7.7R14
205/70R14 = 25.3x8.1R14
215/70R14 = 25.9x8.5R14
235/60R14 = 25.1x9.3R14
245/60R14 = 25.6x9.7R14
25" Tire Diameter
165/80R15 = 25.4X6.5R15
185/70R15 = 25.2x7.3R15
195/65R15 = 25x7.7R15
195/70R15 = 25.7x7.7R15
205/65R15 = 25.5x8.1R15
215/60R15 = 25.2x8.5R15
225/60R15 = 25.6x8.9R15
265/50R15 = 25.4X10.4R15
275/50R15 = 25.8x10.8R15
good luck
awesome! thanks!!!!!!!!!!!!!!!!
