Hi all,
I just finished the front passenger (struts, rotor, and brake hose) and bled the brakes. Tested the brakes (drove back & forth and around the block)and went fine. Went over the driver side, jack it up and can`t turn the front driver wheel.
Removed the brake pads and the rotor starts to turn (by hand). I compressed the caliper and it went in to its normal position.
I haven`t open up the caliper but suspect the caliper is seized. Can you confirm this? Appreciate your feedback with some advice.
P.S. If I ended up overhauling my calipers, what are the part numbers for those? (93 previa, no ABS, with rear discs).
