Results 1 to 7 of 7
Thread: Oil pressure light on for a few seconds at start-up?
    1986 5 speed passenger, 88 Cargo auto
    May 2015
    Southern CA
    Is this normal...
    -Drive the van, park, and start 20 minutes later - red oil pressure light comes stays on for a few seconds at start-up.
    -Drive the van, turn off, start again immediately - oil pressure light goes off almost instantly.
    '87 5sp 4WD custom westy
    Mar 2015
    Kalifornia
    Re: Oil pressure light on for a few seconds at start-up?
    My van was doing that too. Previous owner said it was normal. He was running Dino 20w50 when I got it.
    I changed the oil to synthetic 5w30 and it went away almost immediately. I would guess there was some varnish or gunk on the sensor and they syn oil cleaned it off. Or it failed completely. Not sure exactly what changed, but it doesn't come on anymore.
    Maybe worth trying.
    Edited to add: Make sure your using an OEM Toyota Oil filter or quality aftermarket that has a diaphram. My problem was not filter related, but yours may be, so take a look there first.
    90 2ct townace 4wd
    Dec 2014
    earth
    mine does this when its cold for up to 5-6 seconds before going out (diesel van) 10w40 oil, new oil pump, clean sump.
    but go's out very quick if the engine is starting at normal running temperature.
    Toyota Van
    Jun 2015
    LA
    Mine does the same thing kind of it just randomly turns on and off throughout driving it. The guy that I bought it from said its a bed sensor?
    90 2ct townace 4wd
    Dec 2014
    earth
    Quote Originally Posted by vanalogs View Post
    may just be a bad contact where the black/yellow cable meets the oil pressure sensor its a plastic slide fitting, slide it off, and clean it up with a soft wire brush and something for cleaning electrical contacts.
    while the BK/YL cable is off use a small piece of wire to connect the free end of the cable to the chasis and you should see the dash light go out, that would qualify the cable as continuous.
    Toyota Van
    Jun 2015
    LA
    Quote Originally Posted by adamh View Post
    Thanks adamh Ill try that today.
    FYI, since the oil pressure light gets it's ground from the sender, the light will only light up if that connection is good. Aside from low oil pressure, other reasons for it to light up would be a faulty sender or a short on the wire going from it to the light. My van had an intermittent short in that wire. Even with the sender disconnected the light would come on at times. In the end I ran a new wire from the sender to the instrument cluster.........problem solved. Tim
