Results 1 to 6 of 6
Thread: How to wire up LEDs to door jamb switch for courtesy lights (polarity issue?)
    Previa LE S/C
    Jan 2014
    California
    I tried hooking up some courtesy LEDs I bought to the door jamb switch today, however I ran into issues with the polarity.
    When the door is open and the dome light is on, I connect the LED leads and get no light.
    When I close the dome light (turn it off from "door"), I connect the LED and voila... light!
    I am not knowledgeable with electrical-related systems so how would I go about fixing this issue? Do I need a relay or just an in-line diode? If so, which one? Thanks in advance
    Previa LE S/C
    Jan 2014
    California
    Re: How to wire up LEDs to door jamb switch for courtesy lights (polarity issue?)
    Figured it out! I have warm LED courtesy lights on each side of the the step sill/plate for the sliding door. I also added a sheet of anti-slip grit tape for security since the plastic can be slippery when wet.
    Van Addict cvtroger's Avatar
    95 Previa LE S/C
    Jun 2014
    SF, Cali
    pictures please!!!
    Previa LE S/C
    Jan 2014
    California
    Hi fellow Bay Area Previa pilot! I'll be making another thread about my crazy all-out LED upgrade. By the way, I saw your DIY sliding door repair video on Youtube. It'll come in handy when I get around to it, thanks!
    Mar 2013
    SL,UT
    It would have been nice if GreenLantern had explained what he did to fix the lighting after initially asking for help. A solution which was informative to others would have been a simple addition by the OP.
    Anyone had this issue, or who knows what was going on, who might care posting to save people from the same problem? This is a great-looking mod.
    '88 4x4 5 speed manual
    Dec 2018
    ME
    similar issue to original Green Latern post. My dome lights come on/off fine with the door jam sensor, but my step light does not.
    If I ground the step light with a new wire, then the step light comes on, but does not go out when I toggle the door sensor PLUS now the dome light stays on all the time.
    hmmmm.
