(Cold Start Injector Time Switch) Just unscrew the old and screw-in the new. This goes into your cooling system so you'll want to do a leak check after (with engine hot) to be sure it seals up. Unfortunately this is an expensive switch. Depending on where you purchase, aftermarket and OEM will cost about the same.
Toyota part #89462-20020 has the MSRP of ~$190, but some of the internet discount Toyota parts outlets will sell it for ~$140.
Beck/Arnley part #1580034 goes for ~$155 on
www.rockauto.com. If Toyota still has these I'd recommend ordering from them. It's not likely your local dealer will have this in stock, so you might as well save the $50 and order on-line. For us in the PNW,
www.1stToyotaParts.com is probably who I'd recommend. Tim
