Hi All,
Brand new to the forum, & asking for help already.
Going a little nuts here. Hope you can/will help.
All that the Toyota parts people around here can say is "the book says..."
anyway,
Going to change out the front springs on my 91 all-trac. I'm seeing 3 different p/n for them, each side. The weird thing is the left side p/n for the early 91s supersedes to the late right side p/n. Does this make any sense to you? I have a Feb of 91 date code.VIN: JT3AC22S4M0011566
Could the later p/n units be more heavy duty?
(from Toyota PartsZone East)
48131 SPRING, FRONT COIL, RH **131-28090 1 1990.01-1990.03 TCR20.. 07S $135.98 $101.29
48131 SPRING, FRONT COIL, RH **131-28090 1 1990.03-1991.08 TCR20 $135.98 $101.29 *
48131 SPRING, FRONT COIL, RH **131-28510 1 1991.08-1995.08 TCR20.. 07S.. EFI $156.61 $116.65 *
48132 SPRING, FRONT COIL, LH
Replaced by: **131-28510 **131-28100 1 1990.01-1990.03 TCR20.. 07S $156.61 $116.65 *
Replaced by: **131-28510 **131-28100 1 1990.03-1991.08 TCR20 $156.61 $116.65 *
48132 SPRING, FRONT COIL, LH **131-28520 1 1991.08-1995.08 TCR20.. 07S.. EFI
I see my "correct" p/n is 131-28090 & 131-28100 (replaced by 28510) if I could get some info on the later units being HD I would prefer that route.
Also, what is your opinion on KYB struts vs the OEM?
Thanks in advance,
-Jay
