Is there a chance you shorted something or maybe hooked up the wires backwards? Sometimes due to past mods, there may be more than one wire per post. In these cases it's easy to lose a wire behind the battery. Just make sure they are all accounted for and in the right places. There can never be enough emphasis put on all terminal connections being clean & tight. If all that checks out, the next place to check is the 1.25B fusible link (djshimon linked you to that thread above) I'm guessing that one is blown or somehow messed up. Tim
