Results 1 to 12 of 12
Thread: Lifting leaf springs?
    1987 4x4 TV.
    Feb 2015
    Hilo Hawaii
    Any one know what parts are necessary to lift the rear end with leaf springs? My current 4x4 has coil spring but my parts van has the leafs and Im considering swapping them to my 4x4. I also have a friend with a 2wd and same deal, leafs in back and we wanna give him some clearance to get to the secret beach spots here in Hawaii. I found info on coils but no luck on leafs. Any help would be great.
    Aug 2012
    Tacoma, Wa
    Re: Lifting leaf springs?
    Leaf springs are an easy lift. Longer shackles. This can be as simple as two plates per side with a hole top and bottom or something more elaborate like this. http://www.4wheelparts.com/Suspensio...FQdsfgodNDMNDw
    These are just an example and not a direct fit to the van. When using shackles the lift is half of the extra length of the shackle. So if the shackle is 2" longer the lift is 1". As far as swapping coil to leaf? You better take a closer look at the two suspension systems. I may be wrong because I don't have any personal experience with the leaf suspension but, I believe you're in for major reconstructive surgery of your rear frame.
    1987 4x4 TV.
    Feb 2015
    Hilo Hawaii
    Again Thanks for the reply and info. Youve helped me on two threads today. So if I want 2 inches of lift , then I need to add 4 " of material? I think I may just fab up my own from some stock ones and extra steel off of the parts van.
    1989 Toyota Van Cargo 5-spd
    Aug 2017
    Oakland, California
    Re: Tires, tires, tires!
    Hey all! I've got some 27" General Grabbers on order that'll be here in a few days. I've cranked up the torsion bars in anticipation for their arrival and looking good in the front! Got like 2" of lift there, and pretty sure they'll have no trouble fitting with some light trimming of the plastic tab mount up front.
    My question is about the rear though. I have a leaf spring cargo van and kind've only just realized the whole spring under axle vs spring over axle issue. I bought some 'lift blocks' but as some of you might know, lift blocks are also *lowering blocks when the leaf springs are UNDER the axle - like cargo TVs. So I think the next easiest thing would be to extend the spring shackles? Has anyone done this or have any other suggestions? Would greatly appreciate it!
    Here's an example of what I mean -
    http://1.bp.blogspot.com/-HCcl61gAq3...e-Up-Hung-.jpg
    Aug 2012
    Tacoma, Wa
    Shackle lifts are the cheapest and easiest lift for a leaf sprung vehicle. There are issues that can arise with too long of shackles but for what you are trying to achieve you should be fine.
    Aug 2017
    Oakland, California
    Thanks! You were right! I went down to a local performance shop that just so happened to have some of these universal shackle straps that fit perfectly. The back is now sitting up higher and as close to level as I can get with the front of the van. I'll post some pics later! Thanks for your advice!
    Did you remember to action the LSP & BV?
    Aug 2017
    Oakland, California
    I have not! Thanks for the reminder. I haven't driven it yet and good thing! I'll check the forum for that thread. I remember seeing something about that somewhere around here...
    '86 2wd Cargo On the hunt for a 4wd Hi/Low Auto
    Jul 2018
    West Coast
    Quote Originally Posted by swamptony View Post
    I'm glad this worked out for you. Btw, the 2wd cargo rear leaf spring/axle setup is almost identical to the 5-lug 2wd pickup. I recently had a tire credit $$$ so I went for a set of grabbers. I opted for an add-a-leaf insert with the addition of a slightly longer shackle (e.g. 2" longer shackle gives 1" lift). Many 4x4 companies recommended not to go beyond a 2" shackle extension unless you have a center shackle brace added for support and you can ensure proper geometry coming off your rear axle.
    For those who are interested...
    Here's the add-a-leaf I used: https://www.amazon.com/Explorer-Pro-.../dp/B0007Y5W66
    Here's the shackles that I trimmed down to 5-1/2' center-to-center instead of making my own: https://www.amazon.com/Superior-13-4.../dp/B00029K202
    And for cranking the torsion bars: https://www.amazon.com/Sunex-2-Inch-.../dp/B006L23SPA
    Here it is with the grabbers...
    Van Enthusiast bushcat's Avatar
    '85 Toyota 2WD Cargo Van 5 Speed ------------------ '89 Toyota 4WD LE Auto ————————
    Dec 2017
    Benicia, CA
    Thanks MTN_Van for the product links. I'm looking to lift the back end a bit because it's starting to sag with the weight in the back from my camper build out. Does anyone have any more detailed instruction on how to go about lifting the back with an additional leaf spring?
    Any of the older Toyo pick-up forums should have everything you need to know about leaf spring mods.
    IH8mud and Toyotaminis come to mind but there are many others.
    Jul 2018
    West Coast
    Quote Originally Posted by bushcat View Post
    There are a ton of Youtube vids on installing add-a-leafs (and shackles), so it's pretty straight forward.
    *also replied to your DM
