originalkwyjibo
If you have an owner's manual it details how to open and close the sunroof manually. If your factory tool kit is still present, it should have a flat tip screwdriver for opening and closing the sunroof. The first thing to do is remove the plastic trim panel containing the sunroof controls by gently prying it down. Once this is off you should see a large slotted screw head. Removing the screw disengages the motor from the drive mechanism. Under the screw is another slotted drive you can turn which will open or close the sunroof.
