I have an Aug. 1986 LE Automatic 4wd van that was originally imported to Hawaii without cruise control. It seems to have the plugs on the harness and has the housing for the Actuator on the driver side floor. My donor van is a Sept. 86 Manual, not an LE.
The factory manual mentions a Clutch S/W for the manual cruise control system and a Neutral start S/W for the automatic system. I'm hoping that the system will plug right into the Automatic LE van. It already has a neutral start switch, I'm hoping that will work for the cruise control system. I don't see any other differences mentioned in the manual.
I have done some searching online. It seems that the topic was covered on another Toyota Van site but I can't access that info, no response, even after joining the group. I guess its toast. I also found parts listed on toyota sites that were not encouraging. I saw parts listed for cruise control systems that seemed to have big differences between the manual and automatic vans. It appears that some Automatics don't use the computer that is housed right of the glove compartment, but instead have a different ECU to handle the cruise control? I'm hoping that was not the case for my van.
Can I simply plug the Manual cruise control into my Automatic LE? Or would it be easier to place a dixie cup on the horn of a charging rhino?
