Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
Thread: Have Previa - Will Lift
  1. #41
    Toyota Previa 1992 AWD ABS LE Lifted. Toyota previa 1991 rear wheel DX sold Toyota previa 1994 rear wheel non/SC LE sold Toyota previa 1991 rear wheel LE sold
    May 2017
    Santa Rosa, CA
    Re: Have Previa - Will Lift
    Same color I believe, of the one I sold to my old room mate. I replaced the shocks, struts, rear coils and strut mounts, etc on it except the front coils (they need to be custom made now a day $300 because as I understand it they have been discontinued, would be nice to find an front coil of similar specs to the Previa from an different make and model) and had new tires on it. She lives in that area of Seattle. Though my intuition is thats probably not the same rig. ~ ; ~
    Edit: Ooo I took a closer look and now id bet its the old 91 DX i used to own (I loved that van) It has the dent on the back!
  2. #42
    Oct 2015
    the great Pacific Northwest
    Regarding Previa front spring availability, RockAuto lists complete Sienna strut assemblies (strut, spring, cushions, mount, etc.). The upper end of the spring is different from the Previa, but, assuming the 3-bolt pattern is the same, it should work.
    https://www.rockauto.com/en/catalog/...assembly,15174
    As a bonus, the springs should be stiffer than the Previa because of the Sienna's front engine configuration.
  3. #43
    May 2017
    Santa Rosa, CA
    Thats awsome Tbuyan! ^ _ ^ I may well end up trying this out. first id cross reference the specs for ride hight, order one and an previa strut mount to an auto parts store to compare the bolt pattern.
    My current previa I believe has an bent frame from the look of it and what the alignment shop says (quarter of an inch off or so), so first ill try bracing the frame and pulling on the one end to try twerking the frame before I buy another AWD previa but my eyes are sorta on the market again. ~ ; ~
  4. #44
    Oct 2015
    No need to check ride height. These are the same struts I use for the lift, but are "loaded" with springs, mounts, etc.
  5. #45
    95 Previa LE SC
    Aug 2019
    Las Vegas
    I'm trying to load these pictures in a logical sequence, but the site refuses to upload some of them. So the sequence is all screwed up. Sorry to jump around so much. The half-inch threaded steel spacer secured in place with bolts down through from the top. No need to tear the dashboard and airbag apart next time I replace a strut.
    I am replacing my struts on my 95 which has an airbag on the passenger side. How do you remove the airbag to get to the top of the strut on the passenger side? I need to do that also because I need to also replace intercooler. Any help would be great. No pics or video online I could fine of any of the tear outs or breakdown of the pass side that included the airbag removal. Thanks MG.
  6. #46
    Oct 2015
    My Previa guru says he removes the passenger side strut without removing the airbag, but I can't see how. Although I don't recall the specific 1-2-3; a-b-c sequence for removing the air bag, i'm certain it was no big deal. However, DISCONNECT THE NEGATIVE BATTERY TERMINAL AND WAIT 30 MINUTES before diving into any airbag wiring!!
  7. #47
    95 Previa LE SC
    Aug 2019
    Las Vegas
    I need to raise the air box and storage box because I need to do the struts and also the intercooler. It leaked and was broken by previous owners.. never swapped.. so I'd like to not have to take airbox out and try the lift of the dash and lock box and the airbag is on top on ours in this version.. so just wanted to make sure i didn't break or fired the airbag while lifter the box with a jack. Any info appreciated.
  8. #48
    Oct 2015
    The intercooler is located behind the bumper cover in front of the LF tire, only on supercharged models. You must be referring to the heater core or AC evaporator, under the dash. In either case, I have no experience beyond what I have already posted.
    Take pictures and post them in a new thread so others can benefit from your experience.
    DISCONNECT THE BATTERY NEGATIVE TERMINAL!!
  9. #49
    95 Previa LE SC
    Aug 2019
    Las Vegas
    Sorry - Heater core - - Wrong one..
  10. #50
    92 Previa
    May 2019
    Pullman, Wa
    What are the benefits of lifting the previa? if I were too do this, would I have to drive more carefully? I just recently inherited a previa and the first time ever as a primary caretaker of a vehicle so I know little to jack squat when it comes to automobiles, but I am learning and trying my best to take care of the only vehicle I have. A friend of my dad's who recently replaced the front right CV and ball joint in my previa said I needed new struts..
  11. #51
    Oct 2015
    Quote Originally Posted by pnwPrevia View Post
    The practical benefit for lifting a Previa (or any vehicle) is increased underbody clearance. Completely unnecessary if you drive only on pavement or well graded dirt roads, and not in deep snow. The impractical reason is because it looks better. Of course, some folks LOWER vehicles for that same impractical reason.
  12. #52
    95 Previa LE SC
    Aug 2019
    Las Vegas
    Can u send a complete list if you had stock and wanted to convert. I have a 95 SC RWD version. I did order the stock KYB changeovers, but see u have other items in the fix. .lifting the rear with what items? Will all items from stock - strut and or mounting pieces are used or it's a whole new front complete front assembly?
    What's the items list?
  13. #53
    Oct 2015
    Quote Originally Posted by Mgonthier View Post
    Read the entire thread from beginning to end. It's all in there.
  14. #54
    92 Previa
    May 2019
    Pullman, Wa
    What are some cons? Iím sure driving slower would be one especially around turns. Iím guessing because it makes it even more top heavy. I havenít driven anything taller than a standard Previa tho
  15. #55
    Oct 2015
    No question it raises the center of gravity (makes it more "top heavy"). That said, the difference is imperceptible; I make no allowance for it while driving. To say it another way: Find something else to worry about.
  16. #56
    1987 Toyota Van MT 4WD 1995 Toyota Previa All-Trac S/C 1996 Toyota Previa RWD S/C
    Oct 2017
    Edmonton, Alberta, Canada
    Just adding an update. Samay in Seattle was able to lift the rear for me but the front left camber was out by 10 degrees post lift on the passenger side, even with camber bolts in the top AND bottom. Must have been in an accident, although everything looked perfect underneath. Had to undo it all unless I wanted to take time to make a custom control arm.
    Camperization went amazingly well though. Final weight with 2 adults is 2100kg. Looking to buy a super-clean one from Samay in Seattle to do a final version I can lift and put on 31's.
    Full tour here: https://youtu.be/JXdwQSGqQtQ
  17. #57
    1991 AWD Toyota previa
    Aug 2021
    South Carolina
    Wow that camper conversion is a great use of space with nice fit and finish!
  18. #58
    1995 Previa AllTrac S/C
    Dec 2021
    Seattle WA USA
    PARTS LIST NEEDED for complete lift
    I feel the Previa is the best vehicle ever made. Iím a mechanic and love reliable, versatile, cool vehicles.
    it would be great if someone could make an actual parts list of whatís needed to lift a Previa.
    what year Sienna struts 06-11 ?
    where do you get the spacer plate?
    Anyone have luck with good rear shocks- Koni, Bikstein or gas adjust? Sachs is available.
    gabriel Ultra is most expensive on rockauto. Best ride?
    excel-g is probably too soft. I want good ride and cornering. Not jarring though.
    brake hose application or part number? I found Brake hose 38652 from another post. Napa has it.
    rockauto has a good selection and fair prices.
    Can we put together a parts list amongst all of us? What has worked the best for front and rear complete lift? I can weld, so letís do this.
    3Ē lift with tires sounds great. What tire size are you guys liking most?
    Iíd be willing to put together kits if needed for others once we have a dialed kit. I can have parts fabricated if needed.
    Peace
  19. #59
    Midwest/Southwest/Northwest
    There are also some lift threads on the Previa forum at ToyotaNation too. I only look at the pictures and don't read them too carefully because its beyond my skill set and motivation level so I know I'll never mess with it. But maybe they can answer some of your questions
