Results 1 to 15 of 15
Thread: no brakes at all
    1984 Toyota van wagon le
    Dec 2012
    Dallas
    no brakes at all
    stored my 1984 2wd 5 spd van for a year. when i came to get it it started up without issue, but the brakes go to the floor with no stopping power. i tried bleeding them and adding fluid but i barely helped at all. I'm not sure where to start can someone point me in the right direction?
    Louisville, KY
    Re: no brakes at all
    Is the reservoir holding fluid? Bleeding until no air and all bleeding valves are operational?
    If so then you either have a leak or the master cylinder is shot. Check you rubber lines at each wheel and for signs of brake fluid leakage as well as the front calibers and rear cylinders. Hydraulics are pretty straight forward in that it's a sealed system.
    If it is the master cylinder I've never had to replace one on a TV so hopefully someone can provide more detail.
    Dec 2012
    Dallas
    Ok so I think it's the master brake cylinder. I w as able to shove me phone up in there and take a video. These are some screenshots of that video. This part has a bunch of what looks like rust and brake fluid at the back of it. Where can I find a replacement part and how do I access it to replace it.
    Jan 2016
    Red Bluff, Ca
    I am going to be replacing my master cylinder on my 1985 this weekend and I will post lots of pictures and a step by step process. I said I would do that for the manual transmission replacement on my 86 and I have not yet done that but it is coming!
    Jan 2016
    Red Bluff, Ca
    You can order a new brake master cylinder on www.rockauto.com
    The price varies from about $32 to $92 plus shipping.
    Dec 2012
    Dallas
    Is that what I'm seeing in these photos? It doesn't look like the master brake cylinders in the photos.
    Dec 2012
    Dallas
    Ok I ordered another brake booster. The brakes work if I put fluid in and bleed the lines but they're weak and dangerous to cruise on. So I figured the booster is bad. Now if I can figure out how to get to it and remove the existing I'll be in business.
    Jan 2016
    Red Bluff, Ca
    You should buy the factory service manual for your year of van. They can be had on ebay rather reasonably. You will need to remove the instrument cluster and vents from the drivers side of the van.
    I see you are in Dallas. I am going to be in Dallas/Ft. Worth from March 27th to April 16 for Bell 205 factory school and if you need a hand in the afternoons when I am out of school I would be glad to help.
    You should also try the search feature (upper right corner of all forum pages). I typed in "Master Cylinder" and got lots of great information....probably more and better than the manual will give you. Here's a few of the better ones:
    http://www.toyotavantech.com/forum/s...aster+cylinder
    Louisville, KY
    Here's what the manual says about testing the brake booster. Might want to try this before replacing it.
    OPERATIONAL TEST OF BRAKE BOOSTER
    NOTE: If the booster leaks or lacks vacuum, repair
    before testing.
    1. OPERATING CHECK
    (a) Depress the brake pedal several times with the
    engine off, and check that there is no change in the
    pedal reserve distance. .
    (b) Depress the brake pedal and start the engine. If the
    pedal goes down slightly, operation is normal.
    2. AIR TIGHTNESS
    (a) Start the engine and stop it after one or two minutes.
    Depress the brake pedal several times slowly. If the
    pedal goes fartherest down the first time, and gradually
    rises after the second or third time, the booster
    is air tight.
    (b) Depress the brake pedal while the engine is running,
    and stop it with the pedal depressed. If there is no
    change in pedal reserve travel after holding the pedal
    for thirty seconds, the booster is air tight.
    Dec 2012
    Dallas
    Master cylinder came out easy enough but I'm having trouble removing the booster. Any tips? It's hell for a big man in there.
    Why would you remove the booster.........did it fail too?
    HB - Boosters practically never fail, when they do, the result is usually a massive vacuum leak from a breached diaphragm.
    Check valves can go too (also very rare), but there are simple tests to rule both of these out (see Brenthlehr's post above)
    After having been sitting for a year, I would be more inclined to do a full brake service then bleed the brakes again (don't forget about the 5th bleeder screw).
    Nothing like seized callipers/sliders to make the brakes seem ineffective.
    Dec 2012
    Dallas
    I decided to put my new cylinder on and test it and you are correct, the booster is fine. So my new question is:
    Anyone want to buy a new brake boster for a 1984 van let haha
    I used to remove these on my old school street rods and put back together after they were polished/chromed, but never removed one due to failure.
