Results 1 to 8 of 8
Thread: Spare tire tools?
    1986 Toyota Van
    Oct 2015
    Alabama
    Spare tire tools?
    Wondering if there is a thread already.. Or if somebody could post a picture of the original set of spare tire equipment/tools and jack for these vans?
    ____________________
    1986 2wd auto cargo van
    1986 Toyota Van
    Oct 2015
    Alabama
    Re: Spare tire tools?
    Nobody has a OEM tool kit that they have pictures of?
    1985 Toyota Van 2WD 3YEC Auto Trans. Silver (Toofus) 1987 Toyota Van 4WD 4YEC Manual Trans. White (Doofus)
    Jan 2016
    Red Bluff, Ca
    I do but I am out of state for 3 weeks. If nobody posts before then, than I will post a picture when I get home.
    Van Enthusiast brentlehr's Avatar
    1989 A/T Vanwagon - 2 WD x 2 1986 A/T LE - 2WD
    Jan 2012
    Louisville, KY
    Here ya go. There's not much there really. Just a jack and a lug wrench.
    Here it is mounted in the access panel in the drivers rear hatch. I had to add a small bungee cord to keep it from rattling like crazy.
    1986 Toyota Van
    Oct 2015
    Alabama
    Thanks! Just what I needed!
    Aug 2012
    Tacoma, Wa
    Sunroof models also got an "L" shaped flat tip screwdriver to manually operate the sunroof in case of motor failure and 4WD models came with a small plastic dish similar to a heavy duty version of a lid for a plastic cottage cheese container. This went over the front wheel center caps to give you something to tap them on with.
    Aug 2012
    Tacoma, Wa
    I ran across this EPC image. The disc marked 09183A is the tool for installing the open center caps on the front of 4WD vans that I mentioned above.
    4x4 Cargo
    Mar 2016
    Cedar City, UT
    do you have a part number for the OEM jack by chance? im trying to find a replacement (or something from another yota that's similar)
    i'd like to get the toolkit, jack, and everything if possible but it doesn't look its NLA...
    UPDATE: sorry for bringing up this old post! i finally found the part number - 09111-28030
