- 2
Re: 91 Previa Alltrac, Transfer case and AC problem
Just in case others are looking at this with their transfer problems, search "disabling Alltrac" and you'll find another useful thread.
My particular problem, the tight turning radius wheel skidding thing, was not solved by simply removing the front drive shaft. No power to anything when I did that. Locking the transfer plus removing the front drive shaft did work. For the record... 12k miles on the locked transfer and no issues. See other thread or repair manual for locking method.
Jonny.
Any chance you can give some direction on where the magnetic clutch relay is? I have the electrical manual for my 95, but where the manual shows it, it is not. I've looked all behind the radio and HVAC controls, under the dash and behind the glove box and can't find it at all, despite my manual showing it just right of the ash tray. Any help would be appreciated.
