When I purchased my 87 2wd , it came with a pile of receipts for most of repairs and maintenance from the three previous owners. While organizing all these I found one invoice for an 1997 engine replacement. It clearly stated the use of a 3Y'engine. The sticker on my engine valve cover clearly says 4Y . Witch brings up some questions:
1) Who in a sober state of mind would swap down from 4Y to 3Y?
2) Can a 4Y head be fitted ton a 3Y block?
3) Is the 200cc/ 0.2liter difference in the stroke or the bore?
4) What else has to be messed with to make it work? ECU? injectors? wiring? vacuum and valves? sensors?.....
5) Can the 4Y valve cover be mounted to the 3Y head?
6) Is there some visual clues to identify a 3 or 4Y head?
7) Is there some visual clues to identify a 3 or 4Y block?
