Results 1 to 5 of 5
Thread: Haven't moved my van in 2 years! A couple questions
    Forum Newbie XxCisnerosxX's Avatar
    1987 Toyota van LE automatic (painted like the mystery machine)
    Aug 2014
    Gilroy
    Question Haven't moved my van in 2 years! A couple questions
    So long story short, the last time I really drove my van was around march of 2015, I did pass smog in April 2014.
    Stopped driving it due to not having money for repairs and something else always happening after I made an expensive fix.
    Currently I have bought the biggest battery I can for the 87 Toyota Van LE RWD. (Since old one is dead)
    Will purchase a new radiator as well. (Due to currently leaking radiator)
    Do I need to look out for anything else? It's been in my garage this whole time, do I need to worry about tires cracking? I purchased some tires around Summer of 2013. And I honestly don't remember the maintenance that's been done on it from when I purchased it in 2010.
    I just know that it needed a new radiator and I had the rack and pinion replaced in January 2016 due to leaking power steering.
    Anything helps! Thanks!
    1985 2wd Manual LE
    Mar 2015
    United States
    Re: Haven't moved my van in 2 years! A couple questions
    -Check for codes.
    -Since you are replacing the radiator, you should do a coolant system flush, check your coolant hoses for cracking and replace the thermostat.
    -Hopefully, you put fuel stabilizer in it before storage. Burn through that tank of gas and then change the fuel filter.
    -Check all the vacuum hoses and belts for cracking. I wouldn't drive much on cracking tires, but that's me.
    -Replace your transmission fluid. Replace your rear diff fluid.
    -Flush your brake and clutch fluid(if u have one).
    While you do that stuff, keep an eye out for anything else that looks damaged. Start there.
    Apr 2015
    wherethevanisrare. FL
    Not quite two years but old gas?
    LG.
    Apr 2015
    Oops beat me to it!
    LG.
    1985 2wd Manual LE
    Mar 2015
    United States
    Yeah. The last thing anyone wants is a gummed up fuel system. Fuel gauge won't work, fuel pump/lines clogged, fuel filter botched up, etc.. I put stabilizer in just for a 6 month storage period.
