- 0
How to run amp wire from battery in previa
I was wondering how some of you ran the positive wire from the battery to the trunk section. Do I drill thru the fire wall or run the wire under the bottom. Lmk your opinions.
Re: How to run amp wire from battery in previa
While I've not done this myself, I'd run the power lead from the big terminal on the starter, with a fuse right after, then along under the body.
Look for an existing hole to run the line up into the trunk, but if you can't find one I'd drill, install a grommet, and seal it up with caulk.
You'll still need to run the radio-on signal wire in the cabin, but that's a smaller gauge wire and easier to tuck.
- 0
So run it off of the starters positive terminal instead of the batteries?!
That would save a lot of wire!!
