Results 1 to 19 of 19
Thread: Toyota Van EFI 1986 MYSTERY??!!.. crank but won't start
    Toyota Van Wagon 1986
    Dec 2016
    Puerto Rico
    So the van was running great and suddenly lost acceleration and had to pulled over. That day I made the Van start and run about half a mile but with the same problem of shutting down with acceleration... after I got home I could never make her start again so we replaced the gas pump, replaced sparks, check with another computer and nothing we also checked the air flow meter but it seems fine distributor as well... the van crank and you actually believe that is going to start because it feels like it but nothing... any suggestions or help please I'm trying to check or replaced the parts that can make this problem
    1985 2wd Manual LE
    Mar 2015
    United States
    Re: Toyota Van EFI 1986 MYSTERY??!!.. crank but won't start
    I'd check for vacuum leaks next.
    Van Fan Dogfish's Avatar
    (2) 86 2WD auto LE's (Daily driver has 335k+miles) (1) 87 4WD auto Conversion (90k orig miles) (1) 87 4WD auto LE (1) 88 2WD auto LE (1) 89 4WD auto Conversion (1) 89 4WD auto LE... Still lookin
    Sep 2010
    SW Pennsylvania
    Are you sure that you have spark..?
    It never fires at all..? Even a pop or two..?
    Fuel, air and spark should yield fire.
    You could always try a minimalist shot of ether...
    I don't like using it myself, but as a diagnostic tool it is a quick way to rule out air and spark as variables.
    Dec 2016
    Puerto Rico
    I met a mechanic who owns one of this van and he told me is the air flow meter... because is not electric the van sounds as the tank was empty and is full and we replaced the gas pump... he told us that it looks like the injectors are not opening :/ any thoughts
    Dec 2016
    Puerto Rico
    UPDATE: we change the air flow meter and the van is doing the same... :/ I'm posting a video of me trying to start the van...
    Dec 2016
    Puerto Rico
    Here is the video:
    1985 2wd Manual LE
    Mar 2015
    United States
    Did you do this?
    Replace your fuel filter.
    Check for vacuum leaks.
    Check for a spark at all four cylinders.
    Check your timing, while someone is cranking.
    Check your compression.
    Dec 2016
    Puerto Rico
    We did all that. Now they told me it could be the module...
    Dec 2016
    Puerto Rico
    Quote Originally Posted by islavan View Post
    They told me is the Igniter Assembly Part # 89620-28040
    Van Addict AD2101's Avatar
    1988 4x4 Van Formerly: 1986 Cargo Van Parted Out: 1989 4x4 Van, 1987 4x4 Van, 1986 Van
    Tucson, AZ
    If your van has a tachometer installed on it it's easy enough to test the igniter, just check out this thread.
    Dec 2016
    Puerto Rico
    Quote Originally Posted by AD2101 View Post
    My van doesn't have a tachometer... I will try to find an igniter to test it... thanks for all the help
    Jan 2017
    Tulsa
    Sounds like still not getting any fuel.
    Can you check fuel pressure?
    Tucson, AZ
    Quote Originally Posted by Andywear View Post
    To me that's what it sounds like too, maybe a really bad fuel pressure regulator? Tim has a good article on how to test this here.
    Dec 2016
    Puerto Rico
    That was our first thought that's why the first thing was a new fuel pump but no :/ and we already checked the fuel pressure and everything is great, fuel is not the problem... I think the problem is with the igniter or the distributor...
  15. #15
    Tucson, AZ
    I read that you changed the fuel pump but didn't see anything mentioned about the fuel pressure regulator or the actual fuel pressure numbers that it's putting out. Between 38-44 psi is the sweet spot for these vans, if the pressure is above or below that it could create the problems your having now but if you've checked all that then yea I'd go back to trying to source an igniter to test that.
    Edit: if you can't source an igniter locally, I have one in a 89 van that I'm parting out here.
  16. #16
    Van Fan bald josh's Avatar
    86 cargo
    Jan 2012
    washington
    after replacing plugs and wires did you double check the firing order from cap to plug? sounds like it wants to run but is fighting itself???
  17. #17
    Dec 2016
    Puerto Rico
    Quote Originally Posted by bald josh View Post
    Yes we checked that. We haven't done the pressure test but we're going to do it tomorrow but we did replace the regulator from one van I have for parts but I don't really know the condition... try to start it with start fluid and sounds like is going to start its really trying but nothing...
  18. #18
    86 toyota van LE
    Jan 2017
    santa cruz
    i dont know if this will help but i had the pretty much exact same kind of thing happen with my honda civic. it started kind of sputtering on the highway then died complete loss of power. dropped fuel tank and replaced fuel pump cause i was certian thats what it was, changed plugs, changed fuel filter changed distributor cap and rotor nothing worked. turned out to be the ignition coil. i would replace it asap before you go any further. mine was under the distributor cap when you take it off. was super easy to replace took me 5 min. and cast like 50 bucks. again this was on my honda but im assuming that its gonna be pretty much the same.
  19. #19
    86 cargo
    Jan 2012
    washington
    I agree with checking the coil, not only for spark but without spark the fuel pump wont run. if the coil is working intermittently I could see a situation of a little fuel and spark looking like the video you posted.
    the coil IS under the cap easy to get to. and is fairly inexpensive.
    Ive always been told coils don't fail, but ive had a couple fail including the one in the van I am currently driving ( I needlessly replaced the fuel pump before finding the faulty coil)
