Results 1 to 8 of 8
Thread: Headlight rewiring guide (headlight relay plug melting)
    1985 2wd
    Berkeley, CA
    Exclamation Headlight rewiring guide (headlight relay plug melting)
    In reading the threads, it seems the headlight relays are a common point of failure, with melted wires and fuse box plugs. (Discovered this after the wires into my own relay heated to smoking hot)
    Id like to create a resource guide to wire in aftermarket relays and harness/wiring blocks.
    i have a couple questions to get started.
    I haven't been able to source a wiring diagram. Does anyone know the color codes of the high beam and low beam control wires?
    Van Fan terrence's Avatar
    Mar 2015
    Greensboro, NC
    Re: Headlight rewiring guide (headlight relay plug melting)
    Here is the wiring diagram, headlights towards the bottom:
    http://toyotavans.org/community/tips...NGDIAGRAMS.PDF
    1985 2wd
    Berkeley, CA
    Many thanks Terrence! and thanks for the patience- van life has been on hold as I moved everything I own from Oakland back to Portland! And damn it feels good to be home again!
    I took apart the dashboard today and dove into it- but I think I'm missing something about the way these 3 prong relays work. Does anyone grasp how the red-white wire is modulating the high beams?
    I tried it a couple different ways (connecting the red wire to the red-white wire directly to then use the red-yellow and red-green wires as signal wires for the new relays.... but smoke started coming up from the steering column almost immediately... so... don't do that, fellas.)
    Presently, I wired in a new switch between the red power wire and the red-black power to the headlights. This gives me low beams, but no way to switch on the high beams. Does anyone have a firm grasp on how to use the current headlight switch to actuate new relays?
    Van Enthusiast boogieman's Avatar
    abq, nm
    i recently picked up an '87 that had fuse box issues, both a burned heater motor lead and headlight relay/fuses....the previous owner had a shop rewire a relay and two fuses for the headlights. it looks correct but the problem is i get all 4 lights on for low beam and the outside ones change for high beams....i tried another combo switch and same result...not sure what im missing, Name:  20170705_180642.jpg
    abq, nm
    well thats annoying, why is it always the last place you look? after ripping apart the fusebox and dash and checking the switch 3 times i was gonna disconnect the highbeams until i could figure it out...
    i guess this was some sort of fix before the headlight relay/fuses were corrected...?
    1987 Toyota Master Ace Surf
    May 2020
    New Zealand
    Boogieman I know its been years but did you ever figure out why all 4 lights were on for low beam and outside one changing for high beam? I am having the same issue and I also noticed someone had rewired the headlight relay. Interested to know what the problem was. Thanks.
    I have a 1987 Master Ace Surf.
    abq, nm
    they added that ground in the second pic..maybe it was done before the fuses had been rewired to make them work period but im not sure...when i undid the ground all was back to normal
    May 2020
    New Zealand
    Thanks boogieman. I appreciate your response. Glad you figured it out.
