Results 1 to 8 of 8
Thread: Replacing tie rod ends on 86 2wd
    86 2wd cargo conversion
    Nov 2015
    Denver
    Ive got the tie rod end removed from the steering knuckle but Im making no headway on getting the inner or outer tie rod ends separated from the rest of the vehicle. Everything is rusted together. Anyone do this repair? Im finding no info about it online, in the service manual, etc.
    86 2wd cargo van with manual steering.
    Van Fan Cali Cruiser's Avatar
    1987 Toyota Van DX 2wd
    Mar 2017
    California
    Re: Replacing tie rod ends on 86 2wd
    Have you tried a Tie Rod/Pitman Arm Puller? It's one of those tools that you will rarely use, but it's priceless in situations like this. You can find them for cheap, even Harbor Freight has one (Item #62708), although it is a little on the large size for our application. It can still be used, however it must be twisted and held against the tie rod ends to get enough grip to break it loose. There are smaller ones available that work better for the van's small tie rod ends, but I do not recall where they are available.
    If everything is rusted tight, spray with penetrating oil and allow to sit overnight. If needed, spray again and wait another day. Work smarter, not harder. Good luck!!!
    Nov 2015
    Denver
    the tie rod end came off the steering knuckle just fine, it's getting the inner/outter separated from the rest of the van Im having trouble with where it's seized with rust. been going back and forth with a torch and PB blaster
    Nov 2015
    Denver
    The ball joint is free but Im both stuck here, and where the inner connects to the van.
    89' TownAce Auto 87' 4x4 5spd LE 87’ 4x4 5spd Cargo
    SEATTLE, WA
    I'm sure you are, but hey man be careful isn't that stuff flammable? You'll be torched and blasted
    I'm just saying cause sometimes out of frustration we tend to slip on our safety precautions.
    Mar 2017
    California
    You did loosen the bolt on the collar that holds the tie rod end onto the threaded shaft, right?
    Nov 2015
    Denver
    yeah the collar is removed, its sitting right beyond it.
    Ill just keep working at it but this might be one where I throw in the towel and take it to a shop.
    Blue 1987 4wd 5-speed Hi/Lo Manual Hubs - Sold. Grey 1987 4wd Cargo conversion, automatic in repair mode.
    Nov 2010
    oregon
    I think there's a lock-nut on there keeping the shaft from turning. Loosen the nut and the shaft should turn. I could be completely wrong though.
