whatvan
Recently, on a road trip from California to Vermont, I began experiencing higher than usual oil pressure.
I changed my oil before leaving Idaho for Cali. The van is an 89 4wd manual and has 161,000+mi. I was running 10W-40. Everything ran at optimal levels.
On the trip from Cali to Vermont, daytime temps were in the 90s and I was maintaining a speed of about 70mph (slower up big hills) at about 3000rpm. I drove a stretch of 1000 or so miles on the third day of the drive. I wasn't losing any more oil than normal, and I had run through some coolant. However, towards the end of this day I noticed the oil pressure had increased when the temps were up, but after sunset everything would run at acceptable levels.
Upon arrival in Vermont I changed the oil and filter. I opted for 10W-30 thinking that may be part of the issue. I drove about 50 miles after the oil change. The first 25 everything ran smoothly averaging about 40mph (50mph max speed) at 2500-3000rpm, but the second half of the drive the oil pressure increased.
My best guesses are possibly a faulty relief valve in the oil pump or a faulty head gasket (neither task I'm overly confident, or well prepared, to do myself).
Searching this site with the words "oil pump, high oil pressure, relief valve, oil relief valve" and a couple other variations have mostly pointed to head gasket issues, which I accept as a possibility.
I'm looking for any opinions regarding this situation. I haven't been driving it much since I got back to VT, maybe 100 miles total since the oil change. Figure it's time to start ordering parts and switch into tinker mode.
Thanks for any insight you can provide
-Dave
