If you have the courtesy lamps in your doors, then another common place for this sort of problem is where the wires go between the doors and the body (in the door jam area). If yours is so equipped, you might try unplugging the door harnesses one at a time and leave them unplugged long enough to know if the problem still exists or not. If the problem goes away while a particular door is unplugged, but returns when that door is plugged back in, then focus your attention on that door harness. The wires to look at are the red and the red/white. Tim
