Results 1 to 2 of 2
Thread: Are you having trouble finishing your registration?
    Exclamation Are you having trouble finishing your registration?
    It has recently come to my attention that gmail is (again) rejecting all email from our domain. I'm trying to get this fixed (again), but this sort of stuff is definitely not my forte and it's a different issue than before.
    There ARE some things YOU can do, though!
    • If keeping your gmail address is most important to you, hang tight.
    • If you are a new member and immediate forum access is most important to you, please re-register with a different email. I'll manually remove your previous registration so there are no duplicate accounts.
    PLEASE NOTE that re-registration is a temporary option we'll allow for NEW registrations only — doing this for existing members would cause problems with existing content. If you're already a registered member, you can change your email to a different one in your Settings.
    ALSO PLEASE NOTE that using the "contact us" button with a gmail address will cause our reply to you to bounce back to us as "undeliverable" (this is how I finally discovered the problem).
    Finally, if you did not sign up with a gmail email address and can't finish registering, check your spam folder for the activation codes. (This is by far the most common reason why peoples' registrations do not complete.)
    Re: Are you having trouble finishing your registration?
    We appear to have the gmail issue fixed for now. If your registration is one that did not complete earlier, I have manually re-sent the activation codes.
    Thanks for your patience!
