Results 1 to 10 of 10
Thread: Searching TVT successfully and posting new threads
    Searching for tags is the BEST way to find technical content on TVT!
    Tags are added to technical threads and Library articles by Admin and Mods; blog owners are also able to add tags to their individual blog entries.
    To search tags, first click on "Advanced Search"
    Locate the "Tag" field ...
    and begin typing!
    >>> IMPORTANT!!!
    >>> If you are looking for 4WD-specific information, type 4WD in the search field FIRST
    >>> If you are looking for Previa-specific information, type Previa in the search field FIRST
    The software will begin to autofill with valid tag options after a few characters.
    The tags are in alphabetical order, so type another letter to get the software to show the choices further down the list of possible tags.
    If you aren't sure what terms to use or what tags might exist, this COMPLETE TAG INDEX will help immensely.
    For Previas, use THE PREVIA TAG INDEX
    For 4WD-specific issues, use THE 4WD TAG INDEX
    HINT #1: There are NO tags for model years. Don't bother looking for "1984" etc.
    HINT #2: If you do not see the tag you are looking for, try reversing terms for instance, leaking coolant isn't a tag, but coolant leak / loss IS a tag.
    HINT #3: If you do not see the tag you are looking for when using the prefix Previa or 4WD, try the term without the prefix. For example, rusted bolts happen on other vehicles, and ALL Vanwagons have spark plugs even if they are 2WD (imagine that ... )
    HINT #4: If you do not see a tag for the problem you're researching, try a more general term (shocks instead of front shocks), a more specific term (cylinder head instead of head), or an alternate term (blower motor instead of cabin fan).
    The software only allows 25 characters per tag, so we've had to abbreviate some things or leave out spaces between words to make things fit, especially for Previas.
    Select your choice from the tags and click "search now":
    The results will show all currently tagged threads, library articles, and blog entries.
    If you've tried searching tags and still aren't finding what you're looking for, be warned that he on-board vBulletin search function (that "search" box at the upper right) isn't all that great, and most of the advanced search options aren't any better.
    Here's how to get Google to do a better job:
    (1) Open a Google search (as may be appropriate for your device and/or browser)
    (2) Type in "toyotavantech.com" with a colon afterwards: toyotavantech.com:
    (3) Follow that with your specific search terms. Example --> toyotavantech.com: 4WD radiator
    Here's a screenshot of results for the search terms "4WD radiator" in the example above:
    PLEASE post all your unanswered questions in the most relevant pre-existing thread if you still have questions after reading through all the search results.
    ------------> ONE TOPIC PER THREAD, PLEASE !!!! <------------
    HINT YOU are not a topic! Your Van's SYMPTOMS are topics. _A_ specific repair you've successfully completed and documented is one topic.
    Vans and Previas both typically experience similar problems, so it's highly likely that many other people have already worked through the same issues your van is having, meaning that most of the information you need right away is already at your fingertips. When that's not the case, posting in an existing, relevant thread helps you because the forum software also automatically notifies people who have participated in those threads (unless a specific member has turned off that function) this is the fastest way to receive input. It also helps the next person when all related information is contained in a few on-topic technical threads instead of scattered everywhere and buried in chatter.
    Reminder DO NOT post in the 4WD subforum unless you are certain the issues your van is experiencing or the questions you have would never, EVER occur with a 2WD van.
    Note: Inflated ego due to owning a 4WD (and vice-versa) does not count.
    THANK YOU from all of us at ToyotaVanTech.com Admin, Mods, and members!!!
    4x4 Cargo
    Cedar City, UT
    Re: Searching TVT successfully and posting new threads
    Thanks for posting this, I started searching the site this way with google instead of using the built in search bar because its pretty much useless
    Google does an awesome job searching for keywords and helping me find the posts im after. Happy searching!
    1985 Toyota van
    May 2017
    Mt. Pleasant Pa.
    Thanks!!! Great tip!!! Took me 1 second to find the thread I just previously searched for that took me what seemed like 10 min. Jim Z
    89' TownAce Auto SuperExtra 87' 4x4 5spd LE 87 4x4 5spd Cargo
    Gwen thank you taking the time to provide details with pictures on how to do this..... uummm for some of us not so computer savvy members!!
    Your time and efforts are greatly appreciated!!
    1987 Toyota Van 4x4
    Aug 2020
    Berkeley CA
    yeah this is super helpful, thanks Gwen. I feel like this should be pinned at the top of every forum...that would help newbies like me find info easier and save ya'll time not having to look at questions already answered. Amen to the search function being pretty useless if you are just starting out. Def spent many hours stumbling around before I figured that out.
    cheers!
    Quote Originally Posted by jannifiddle View Post
    Good suggestion I'll see if this software will allow me to do that. I know other forum software can, so probably it will.
    Toyota Previa 91 AWD Auto (now dead) Toyota Previa 92 AWD Manual 408K as of 8-13-22
    Jul 2022
    Lakeport, Californa
    Sorry, are you saying 4WD as in the older toyota vans vs. an AWD Previa?
    The tags correspond with the subforums, and with Toyota's nomenclature:
    4WD = Van (not Previa)
    Previa = Previa
    Jul 2022
    Lakeport, Californa
    Thanks for clarifying. I thought I saw a section for electrical issues but can't seem to find it. Can you please point me towards that? Searching didn't work.
    Looking at the Previa tag index (linked above in the first post), I see these two tags pertaining to both Previas and electrical issues:
    previa electrical diagram
    previa electrical problem
