Results 21 to 23 of 23
Thread: DIESEL PUMP FIXES TO AVOID EXPENSIVE REBUILDS AND CURE LEAKS!!!!
    1992 LiteAce 4wd 5spd 2L TD
    Mar 2019
    Sonoma, CA
    Re: DIESEL PUMP FIXES TO AVOID EXPENSIVE REBUILDS AND CURE LEAKS!!!!
    Hi All,
    We have a 1992 LiteAce with the 2C turbo diesel. It runs great but recently developed a fuel leak from what looks like the return relief valve on the back of the pump. I tried to get a picture of it here:
Size:  101.0 KBName:  Inked20210204_114511_LI.jpg
    Has anyone dealt with this before? Does the relief valve fail? Or does this indicate some other problem with the fuel return?
    Any help would be appreciated.
    Thanks in advance,
    Blake
    1989 townace 4x4 turbo diesel
    Feb 2016
    Quote Originally Posted by oli larsen View Post
    ADDITIONAL LEAKS........
    If you find despite doing these 4 seals you still have a leak from the rear of the pump (around where the iron block joins the aluminium body) from the distributive body, and its not just a loose injector pipe then I'm afraid its rebuild time. theres a big o-ring in there that once removed the entire pump needs re-setting up! this, unless you have access to engineering equipment is sadly best left to a professional.
    The seals I've mentioned above though are all well with in grasp of any hobby mechanic!!!
    Looks like I get the pleasure of following your tutorial today! I have a suspicion that my leak is coming from behind that distributive head. In the diagram it looks like you could just remove that head and swap the ring with the pump still in the vehicle. You mention that the pump would need re setting up though. Any insight on that part? If it's just timing the pump, that doesn't seem too bad. I need to track down that tool though that measures plunger depth or whatever it is.
    Thanks for posting all this though. It's a huge head start!
    Feb 2016
    Quote Originally Posted by FamilyDancer View Post
    Hi All,
    We have a 1992 LiteAce with the 2C turbo diesel. It runs great but recently developed a fuel leak from what looks like the return relief valve on the back of the pump. I tried to get a picture of it here: [...]
    Thanks in advance,
    Blake
    Blake, you ever figure anything out with this?
