Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
Thread: Replacing a Previa head gasket.
  1. #41
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Re: Replacing a Previa head gasket.
    Although I want to minimize the work on this job, I decided I better at least replace the valve seals since I have the head off and there are so many miles on the engine. I'm glad I decided to do this as the valves for the cylinder that took the most water were pretty well stuck in the valve guides. I got them freed up. I still have a few valve seals to change. Makes me miss 2 valve per cylinder engines. I did not lap the valves as I don't want to deal with changing shims.
    Finished replacing the valve seals.
  2. #42
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Cleaned up the block deck and it is in good shape other then the pitted area.
    After reading about possible options, I decided to use a small bit of JB Weld epoxy in the pitted area.It takes at least 15 hours to cure. I will file it flat before putting the gasket and head on.
    Here is a SAAB TSB using this solution:
    210_1797.PDF
  3. #43
    1993 2WD Previa LE
    Jun 2017
    Delaware
    I put on the gasket....
    Torqued the head bolts....
    Name:  head torqued.jpg
    And installed cams.
    Will work on connecting all the peripherals and getting the job finished as time permits.
  4. #44
    Quote Originally Posted by tfreed1 View Post
    210_1797.PDF
    Well that certainly makes me feel better about it. If I ever run into that situation I'll likely give it a try. Looking good! Thank you for the awesome documentation and please keep us posted on how things hold up . Tim
  5. #45
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Thanks. The TSB made me feel better about it too.
    Some additional information that may be helpful:
    I drained the oil the day after the gasket blew and there was quite a bit of water in the oil pan. I drained the coolant and refilled the oil and cranked the fresh oil around the engine using the starter. I did not want to leave water in the oil passages for an extended period of time. When (fingers crossed) the engine starts, I plan on running it for a while and then changing the oil again. I plan on adding straight water first, then draining it before adding antifreeze.
  6. #46
    1993 2WD Previa LE
    Jun 2017
    Delaware
    I finished getting everything together and the engine is running well after a few minutes of smoke from the antifreeze in the exhaust and the oil I used while assembling the head. I ran the engine for about an hour to check for leaks and to boil off the remaining water from the inside of the engine. When it cools, I am going to change the oil, drain the water, and add antifreeze.
    I would estimate I've spent 35 hours of actual work time on this job. I spent time getting 26 year old bolts loosened and figuring out what needed to be taken out. I changed the front O2 sensor and had to drill out the studs that were too rusted to get out. I spent a lot of additional time researching how to deal with the head pitting.
    Name:  o2 sensor.jpg
    Leaving the engine in the van made the job possible to do on my own. I would not want to pull the engine without help. I also did not need anything other than a floor jack and jack stands to raise the van or the engine.
    While under the van, I found these supports rusted on both sides and will repair them.
    I plan on using the van to commute to work and will let you know how it is doing.
  7. #47
    Awesome! Thanks for taking the time to document!
  8. #48
    2000 Sienna LE FWD 95 Previa LE SC AWD (RIP) 93 Previa LE AWD (no reverse...stuck in yard...RIP) 91 Previa LE AWD (RIP)
    Midwest/Southwest
    I hope no news is good news.
  9. #49
    1993 2WD Previa LE
    Jun 2017
    Delaware
    I have driven the Previa about 1200 miles since replacing the head gasket and it is running fine. It seems to have a bit more power than before and the gas mileage has increased a bit as well. It has not lost any coolant or oil since the gasket repair. I am going to take it on a trip for the holidays (about 1800 miles round trip) and will give an update after that.
    I replaced the third member with one from a 96 SC last spring and the rear end ratio is 3.73 rather than 4.30 which makes highway driving a bit quieter. I want to see if my highway gas mileage is any better when we go on the road trip. The acceleration is acceptable.
  10. #50
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Drove the van on a trip about 1800 miles of highway driving and it is still running well. Have about 4000 miles with the new head gasket. Van has lost no oil or water.
  11. #51
    1984 Van 2WD 1987 Van 4WD 1988 Van 4WD 1997 Previa S/C AllTrac
    Nov 2018
    NM
    Hi Tim and everyone on this thread. Which is excellent. Iím getting geared up to run this gauntlet and Iíve noticed that since the first time i looked, the photos from the original repost have disappeared. Are they still available anywhere?
    Ethan
  12. #52
    Welcome to the forum Ethan.
    The most current explanation starts on page 2 of this thread.
  13. #53
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Quote Originally Posted by peaquod View Post
    Ethan
    Hi Ethan,
    The latest news on getting the photos back is here:
    https://www.toyotavantech.com/forum/...ome-TVT-images
    It looks like they will eventually be view-able again.
    if you have any questions about the head gasket replacement, ask them here and someone should be able to help. Good luck.
    Tony
