Results 1 to 20 of 33
Thread: Best Lift Kit?
    1986 4x4 toyota van 4 speed automatic Port hole window style
    Mar 2018
    San Francisco
    Question Best Lift Kit?
    I have a 1986 4x4 automatic van, looking for the best lift kit/suspension to put on the van. Looking for like a 2-3 inch lift. I know spacers are an option but the suspension is shot any way so Im thinking about redoing it all. Any suggestions?
    Mar 2018
    San Francisco
    Re: Best Lift Kit?
    Any one?? pleaz
    1987 4wd 5sp
    Mar 2011
    Oregon
    Re: Best Lift Kit?
    Use the search feature. There are multiple entries regarding shocks, Mr. Gasket spacers, torsion bars, larger tires and 15" samurai rims and true modifications of the suspension: a combination of there will get you 2-3 " lift.
    -Good luck!
    Re: Best Lift Kit?
    There is no kit. You have to make decisions about which method is best for your needs and assemble (and/or modify) the parts yourself. Click HERE for the best way to search TVT.
    1987 4x4
    Feb 2018
    Raleigh, NC
    Re: Best Lift Kit?
    Since I spent hours searching through a few threads for part numbers, here is what I did:
    Front:
    2000 Durango 4wd front shocks - Bilstein B6 4600
    - These are ALMOST 100% bolt in. The only thing you need to do is either have the lower bushing machined down (or grind it) to fit inside the stock Toyota lower shock mount. I forget the dimensions, but I think you need to remove ~1/4" on each side of the bushing. They ride amazing with the torsion bar cranked up to get your desired lift.
    https://www.rockauto.com/en/moreinfo...361832&jsn=461
    Tighten your torsion bars to a desired height. Make sure to use a micrometer or machinists ruler to get both sides pretty even.
    Rear:
    2009 Toyota Tacoma rear shocks - PN#: 48530-A9680. Factory Bilsteins.
    (priced each, add 2 to cart)
    https://www.amazon.com/Toyota-48530-.../dp/B00KTJX5IG
    Moog CC845 Springs. These take some trial and error to get your desired height. It was kind of annoying, but prepare to spend an afternoon unbolting your rear end, bolting up your rear end, and cutting your springs to your desired height. I think it took me 3 tries and I ended up chopping 3 coils off the top.
    https://www.rockauto.com/en/partsearch/?partnum=CC845
    Tires:
    I'm running 27x8.50 General Grabber AT2
    Everything ended up settling at a 2" overall suspension lift. The tires added about another 1" of ground clearance because they were taller than the stock tires.
    wherethevanisrare. FL
    Re: Best Lift Kit?
    I'm overdosing on confusing info about shocks, real infos are not very forthcoming from the manufacturer of shock. They rely to much on sale peoples and not
    enough on technical customer service. Can any one tell me the difference between # 24-186056 and 48530-A9680. They are both Bilstein, both listed as Tacoma
    4x4 OEM, one of them is even mentioned as compatible with the van, but I can't find a tech description other than: "this one is designed for a better driving
    experience or handling" Bilstein website is no better than Crapazon or any other off-road accessories vendor. I have picked the Bilstein 4600 series #24-
    185233 (2000 Durango) for the front, and I would like to keep it in the family between front and rear. I need to know fully compressed length, fully extended
    length for both as well as the van's original. Threaded or bushing ends? Thread and bushing sizes? etc. If there is a major difference in valving, it would be nice
    to know also. I would rather make an educated decision based on engineering than " We designed this crap to be as bad as the crap it will replace so you won't
    even feel the difference but it will drive better (sware) that is why you are paying $40.00 more .
    LG.
    vancouver canada
    Re: Best Lift Kit?
    ...maybe not the best lift kit,, but the simplest...
    ...get a second set of springs from the wrecker,,,take the existing set out,, wind them in with the first set,,, re-install....works like a charm!
    If you do this, it's important to lower the brake equalizer by ~2'',, that the little rod between the underbody and the axle.
    1987 4x4
    Feb 2018
    Raleigh, NC
    Re: Best Lift Kit?
    If you call Bilstein or one of their rebuilding locations I'm sure they will give you all the valving info, rates, and droop lengths. Bilstein is an awesome company, you shouldn't have a problem getting that info.
    Re: Best Lift Kit?
    I'm not denying that Bilstein is a good company making good products, and I would love to be able to call and talk to someone at Bilstein and compare numbers and dims etc.. Of course I try to find that "Someone" starting with Google and landing here:https://www.bilstein.com/en/ going to expert near you got me a nice "could not find info" or Email only in California USA Headquaters = wait over week end for answer. Summit, Tire rack, 4wheels parts. com etc... could not come up with better info than the "description" you can find on Crapazon. I physically went to 4wheelparts.com store as they are in Miami and after 10 minutes of digging in their data base the guy could not tell me the difference between # 24-186056 and 48530-A9680. and basically told me to bogg-off (Hey, it's customer service the Miami way )Plus they drop ship only, no stock, so no way to physically compare (Money for nothing. They got their MTV ).
    I got most of the front done, this week end, new upper arms, completely rebuilt lower arms, rebuilt lower ball joints, new hardware and Rubber cushions and new shocks, couple of surprises there, more on that later! Still have to do the sway bar bushings and the front will be all new and good for another 28 years.
    LG.
    Mar 2018
    San Francisco
    Re: Best Lift Kit?
    Just an Fyi you sent the wrong suspension in the link for the front springs -_____-
    1987 4x4
    Feb 2018
    Raleigh, NC
    Re: Best Lift Kit?
    Quote Originally Posted by SpencerReeves View Post
    link possibly changed?
    Mar 2018
    San Francisco
    Re: Best Lift Kit?
    Quote Originally Posted by ncbrock View Post
    You sent the right model shocks, but the rear instead of the front suspension of a dodge durango... my fault really i should have double checked but i just need to send them back.
    Hiace 2000
    May 2018
    United States
    Re: Best Lift Kit?
    I'm also looking for a good suspension lift kit. Will take note of those suggestions. Thanks!
    Van Fan Krab Krust's Avatar
    1988 toyota van 5spd 4x4
    May 2018
    seattle
    Re: Best Lift Kit?
    [QUOTE=ncbrock;32437]Since I spent hours searching through a few threads for part numbers, here is what I did:
    Front:
    Rear:
    Tires:
    Confused here, the shocks listed for the front have the same extended and compressed length as stock so you wont have any different travel, the rears are about the same just a little bit longer but not long enough to work with 2.5 lift in the rear. springs worked great but now i'm here trying to figure out a set up that will actually allow droop in the rear axle and not bottom out on the shock internals
    Re: Best Lift Kit?
    I did the same shocks swap, but I went with theses and the stock springs in the back.
    You have to cut a wedge shaped slice of about 3/8" (at the widest) to fit the van spring, (easy).
    LG.
    Re: Best Lift Kit?
    Could not fit 2 pics in one post Then it flips the pic sideways
    It looks like this when done;
    LG.
    Re: Best Lift Kit?
    Quote Originally Posted by Krab Krust View Post
    I've seen this mentioned a few times. Unless you removed or modified them, your upper and lower control arms still have travel limiters for both compression and rebound(bump stops). You have not altered the front suspensions travel in any way you've only altered it's position at rest. Because of this longer travel shocks for the front are not necessary.
    May 2018
    seattle
    Re: Best Lift Kit?
    That does make some sense for the front, haven't messed with torsion bar before. thanks for the reply
    May 2018
    seattle
    Re: Best Lift Kit?
    Thanks carbonized for the reply, i have already cut and put the aerostar springs in, just looking for a better rear shock option. i need more travel than the bilsteins for the tacoma that everyone seems to use
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Re: Best Lift Kit?
    Check out the post for lifting the rear end...
    I used some Ford pickup shocks with lots of travel... also used the same daystar spacer that Carbonized has listed.
    The shocks were
    2wd 2000 Ford f-150 shocks, Sensa brand part# 1214-0190. They have 9.75" travel... I forget the extended and crushed overall but they were more than adequate.
    Here:
    https://www.toyotavantech.com/forum/showthread.php?6403-Lifting-the-rear-of-your-4wd-van-Coil-spring-edition!
