Results 1 to 5 of 5
Thread: I am getting ready 2 put 2c in my gas 89 4x4
    89 4x4 a pair of 87 2x2 Toyota and parts I have had 9 of them.
    Apr 2018
    near modesto ca
    Post I am getting ready 2 put 2c in my gas 89 4x4
    got most parts 2c runs need to make motor mounts can handle this. not sure about fuel lines got elect figure out.any help . not sure year of 2c.
    93 Toyota townace 4x4
    Nov 2017
    Sweden
    Re: I am getting ready 2 put 2c in my gas 89 4x4
    the fuel system shouldnt be too complicated as its a low pressure system with no electrical pre pump. all you need is a line in to the fuel filter and pump and a return back, the engines themselves are much simpler than the fuel injected ones and will run with just a feed to the glow plugs and a feed to the fuel cut solenoid. good luck with it!
    4x4 Cargo
    Cedar City, UT
    Did you ever do this? I have a bad head gasket and Iíve been interested in a diesel conversion since day 1 of ownership. Iíve never done an engine swap but if itís possible and not too crazy I could probably figure it out.
    wherethevanisrare. FL
    Spacecruiser, at a 6100 ft elevation, you may want to reconsider the C and look at the Turbo version of the 2C. Then It gets a bit more complicated.
    LG.
    Apr 2018
    near modesto ca
    Quote Originally Posted by spacecruisers View Post
    yes it's in and running lots of fabing on the good any 2c manuel trans bell housing will fit up to 5 speed in van don't know about automatic yes it was a bit crazy but if u like this kinda stuff go for it. Always more to do started winch bumper but busy with outher stuff. Keep ON VAN MEN!
