Results 1 to 11 of 11
Thread: Rear air conditioning and refrigerator AC work but no front AC
    1987 4x4
    Feb 2018
    Raleigh, NC
    I tried to get my AC working today after installing a ton of new o-rings, a new compressor, and new drier. The van passes the vacuum leak down test, all the functions of the AC system work. All the buttons work, fans work, idle-up and everything works the way it should. The rear blows pretty cold, and the refrigerator seems like it can make ice, but the front is just ambient air temperature no matter how I aim the air or mess with the fans. Looking for some ideas on what to check or replace.
    Re: Rear air conditioning and refrigerator AC work but no front AC
    I would be looking to the front expansion valve, as the culprit.
    1987 4x4
    Feb 2018
    Raleigh, NC
    Ok it’s getting absolutely brutal outside and still haven’t fixed this issue. Replaced the front expansion valve, cleaned out the evaporator (externally) and isnt clogged internally. I fixed the seal on my hvac blend door and the cables are operating properly as the blend door seals off the heater core when you turn the knob to the blue side. I can’t really tell if the front evaporator is even getting cold because it’s kind of sealed up under the dash. The low pressure line from the front evaporator that is shared with the refrigerator gets icy if that means anything
    Beyond my depth but did a little looking about and found this, while its referencing residential, same principles apply
    It's all about the temperature/pressure relationship, and how pressure affects the boiling point of the refrigerant. As the pressure of a refrigerant goes up, so too does the temperature and boiling point. When the pressure drops, the temperature and boiling point drop as well. Air conditioning (and some heating) systems take advantage of this, to cool (heat) the air inside a building.
    Normal system
    In a normal system, The compressor compresses the refrigerant vapor. This causes the vapor to be both high temperature, and high pressure. The hot vapor moves through the condenser coils, where some of the heat is transferred into the outside air. When the vapor finally comes out of the condenser, it's a hot liquid. The hot liquid moves through the liquid line, into the building towards the evaporator coils. Just before the hot liquid refrigerant reaches the evaporator, it's forced through a metering device. The actual device used depends on the system, but capillary tubes are common.
    When the hot liquid is forced through the metering device, the pressure drops substantially. The pressure drop causes the temperature and boiling point of the liquid to also drop. As indoor air is forced over the evaporator coils, the cold liquid refrigerant in the coils absorbs heat from the air. The heat causes the refrigerant to boil, which changes it to a low pressure vapor. When the refrigerant reaches the end of the evaporator, it's a cool vapor. The cool vapor travels down the suction line, and back to the compressor where the refrigeration cycle can start again.
    Low refrigerant
    When the refrigerant in the system is low, the pressure; and therefore temperature, of the refrigerant will also be lower. In a normal system, the temperature of the refrigerant at the beginning of the evaporator will be right around the freezing temperature of water (32°F). As the indoor air moves over the cool coils, the moisture in the air will condense on the coils. This condensation will drip harmlessly off the coils, and into the condensate drain.
    When the refrigerant is low, the temperature of the refrigerant at the beginning of the evaporator coils will be colder than the freezing point of water (less than 32°F). Because the coils are so cold, the condensation that forms on the coils will freeze. As ice builds up on the coils, it restricts the air flow through the coils. Because of the restriction, the refrigerant can't absorb as much heat from the the indoor air moving over the coils. This causes the refrigerant to boil later in the evaporator, which causes ice to form further along the coils. This situation continues to progress, until the whole evaporator is a block of ice. Once that happens, the refrigerant will start to boil in the suction line. This cause the temperature of the suction line to drop, and just like in the evaporator, cause the condensation to freeze.
    Eventually the freezing works its way all the way back to the compressor, which is where the trouble can really start. If allowed to operate in this condition for too long, liquid refrigerant can make its way back to the compressor. If this happens, the compressor can be damaged.
    It should also be noted. Once the refrigerant level drops too low, the system stops working. So this problem only occurs in a "sweet spot", where the refrigerant is low, but not too low.
    shareimpro
    Not sure, but sounds like you might just be low on freon?
    And from the RedTek site:
    Abnormal Pressure Gauge Readings
    Low Pressure Gauge is High and High Pressure Gauge is High
    Condition normally indicates an overcharged system. Slowly remove refrigerant through low side service port until gauge readings are normal or until proper cooling returns.
    Low Pressure Gauge is High and High Pressure Gauge is Low
    Condition normally indicates faulty reed valves in compressor when this condition is accompanied by extremely vibrating gauge needle. Compressor service is required.
    Low Pressure Gauge is Low and High Pressure Gauge is Low
    Condition normally indicates low refrigerant charge. Add refrigerant until gauge readings are normal or proper cooling returns.
    Low Pressure Gauge is Low and High Pressure Gauge is High
    Condition normally indicates blockage in air condition system. Service is required.
    1987 4x4
    Feb 2018
    Raleigh, NC
    It was the magnetic valve wiring. AC is working perfectly now, about to switch it over to RedTek from R134a
    Sweet!
    Wait, I should say "COOL"
    1986 LE
    Aug 2017
    Florida
    Can you describe where this valve is? I just did all by AC over and finally stopped all the leaks. Hey BB, it was the compressor after all.
    But it get cool but not real cold. The rear is a tad better.
    Maybe I should check this magnetic valve.
    It would be a big help if you can tell me where it is located.
    1987 4x4
    Feb 2018
    Raleigh, NC
    On my 4WD van is is above the condenser (you have to lower it) and it is a cylindrical valve mounted on the drivers side “frame” rail. Shiny metal vavle that says “Nipondenso” on it.
    1986 LE
    Aug 2017
    Florida
    Thank you for your input. I think the 4wdr unit is different. I did find a cylindrical type of something with 2 wires on it in front of the front condenser connected between 2 somewhat thin tubes. I will try to take a pic of it and see if it says anything like Nipon on it.
    It is a real bummer though. The are puts out, at it best, about 80deg if I put a thermometer in the throat of the front middle AC vent. The compressor is still working and the rear, after measuring, really isn't much better then the front. It is basically a waste of time on the extra fuel to run it. It does nothing.
    Maybe by some miracle its the valves.
    Thanks again for the feedback.
    1 1984 Toyota Van Wagon
    May 2018
    Oklahoma
    I’m currently dealing with the same issue. How much was it? And where did you get it? Did you have to drain the system to install?
