Results 1 to 4 of 4
Thread: Steering Column Cover Repair
    1993 Previa DX
    Jun 2018
    Round Rock Texas
    While it's not finished I thought I'd give this a post. I've done several similar repairs on other vehicles all with good success.
    I've seen some videos posted about using longer screws, deck screws, fender washers, etc as a stop gap to hold these back together.
    With a little tape, razor, drill and the right epoxy the busted parts can be fabbed up with relative ease. In this case I used some JB Weld Plasticweld. I've also used Loctite's plastic epoxy, though their new formula isn't as good as it was in the past.
    Don't use a 1 or 5 minute epoxy for this stuff, it just doesn't hold up. The majority of fixes I've seen just using bigger screws to hold things together was because they tried bonding the broken plastic back together with the wrong epoxy.
    I forgot to take some photos of the process but basically what I did was clean the surfaces well, mixed the epoxy and the parts that were large enough to affix, I simply did so. The parts that needed fully rebuilt I used some packing tape to make a tube. In the instance of the larger plastic post with the hole through it I made a tube of tape on the inside as well. For the smaller post I have yet to drill out the center, but this epoxy machines very well.
    Either way, this fix works well, give it a try. I know these pieces can be hard to find and seem to be easily busted, so hopefully this helps some of you out. If it screws in tight enough I may not need to repair the broken clasps at the back, those things seem that they'd be very fiddly so I don't know if the epoxy would hold for that particular fix.
    Cheers
    Van Enthusiast pdgizwiz's Avatar
    '94 LE dual sunroofs "Whistler" -AND- '97 DX SC Alltrac shredder rescue "Elmer"
    Sep 2010
    WA State
    Re: Steering Column Cover Repair
    I've seen this on many cars I've owned. Thanks for the tip!
    1993 Previa DX
    Jun 2018
    Round Rock Texas
    Slight update to this. Do not buy the JBWeld plastic bonder product, about half of the connections have failed so far. I have repairs I have done with the Henkel (Loctite) product that are still holding up 8 years later. Not sure what JB is making this stuff from but it's garbage. My local home depot has stopped stocking the Loctite product though for some reason, so I'll need to hit up Lowes on it.
    Either way, I'll disassemble and rebuild and all will be good again.
    Also another of the Loctite products that works well is their Marine Epoxy. It is a lot thinner though so you need to do more to contain it while it's curing. But once it cures it's very strong. It's more difficult to work due to the hardness but I've repaired several tabs and housings on my civic with it and it's held up great here in the Texas heat.
    On discord? Come Chat https://discord.gg/aZqCZaR
    jonnynof#6917
    Van Addict boogieman's Avatar
    Feb 2017
    abq, nm
    for abs plastic ive had really good luck using plumbing abs glue from the hardware store! works great...not so much on polyethylene or other plastics...
