Page 16 of 16 FirstFirst 12345678910111213141516
Results 301 to 312 of 312
  1. #301
    1988 4x4 Van
    Feb 2022
    Golden, Colorado
    What hose is this?
    Hey all!
    Is anyone able to help me find where to get one of these, or a good alternative for this hose? #22230M on the diagram.
  2. #302
    wherethevanisrare. FL
    Re: What hose is this?
    http://www.sotond.com/Automotive-Rub...pl3009354.html try this contact them and ask for something of the same inside diameter and roughly the same radius and for the same application ( gasoline,vacuum, oil, coolant etc). You can cut some part of a longer, multiple bends, hose. for vacuum look at there flexible silicon. Whatever you chose, do not loose those OEM clamps and re-use them, they are there for a reason.
    LG.
  3. #303
    1988 4x4 Van
    Feb 2022
    Golden, Colorado
    Appreciate it! I’ll check that out
  4. #304
    FYI, those hoses are metric. SAE sizes will not fit well. I tried all different manor of alternatives when I did my head gasket a number of years ago before I finally went to the dealer who was still able to order them at that time. I believe they are 14mm but don't quote me on that. Same with the heater hoses on the vans. Your either trying to stretch 1/2" hose to fit or clamping down 5/8" and hoping it doesn't leak which doesn't work well in the tight confines of the intake plenum.
  5. #305
    1988 Toyota Van LE
    Mar 2022
    Palmdale,CA
    Any idea what this green object might be on my 1988 Toyota Van LE?
  6. #306
    Looks like a broken PCV valve, of the (incorrect) plastic variety.
  7. #307
    1986 Toyota Van
    Nov 2021
    Oregon
    I was wondering what this line is coming from my power steering pump. When I was reading in a thread I saw this like but couldn't tell if it was the same part or not https://www.rockauto.com/en/moreinfo...nid=549&jpid=4 The bends/hook ups on the one in the link seem a little different than the one in the picture. Thanks
  8. #308
    Quote Originally Posted by Temassi View Post
    That's the power steering pressure hose that goes from the pump to the steering rack. Assuming this is for the 86 listed in your profile, I would think this is more likely the appropriate hose. https://www.rockauto.com/en/moreinfo...279751&pt=7320
    Last edited by originalkwyjibo; 06-28-2022 at 11:29 PM. Reason: Stupid autocorrect
  9. #309
    1986 Toyota Van
    Nov 2021
    Oregon
    It is an '86. That looks exactly like the part that I need. Thanks a bunch, I really appreciate it!
  10. #310
    1986 Toyota Van
    Nov 2021
    Oregon
    I was wondering if anyone knew what this was. It's located at about the center of the front bumper, the wire going into the cab is disconnected. It looks like a little megaphone. I thought it was the horn, but I've been able to find that in a diagram and it doesn't look like this.
  11. #311
    That appears to be a left over speaker/siren from an aftermarket alarm system.
  12. #312
    1986 Toyota Van
    Nov 2021
    Oregon
    Oh ok. That makes sense as to why I couldn't find anything in the books on what it was. It's just sitting pretty perfect in what looks like a spot made for it so I just wanted to double check.
