Page 9 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 161 to 180 of 332
  1. #161
    4x4 Cargo
    Cedar City, UT
    Re: Upper throttle body cable broken
    Interesting, mine doesn't have the upper cable.
  2. #162
    wherethevanisrare. FL
    Cruise control?
    LG.
  3. #163
    Van Addict boogieman's Avatar
    abq, nm
    automatic kickdown cable isnt it?
  4. #164
    The repair manual (Page AT-11 and AT-29) calls it the throttle cable.It activate down shift on the AT if I understand
    LG.
  5. #165
    1987 Toyota!
    Apr 2018
    Unhappy What is this wire?
    Hello Van Community,
    Pretty new to the van forum.
    I've been slowly working on the van and plan on driving it to Brazil starting next summer. I came across this wire being cut. I noticed this after the van over heated.
    Would anyone know where and what this wire belongs to.
    Thanks in advance
Size:  92.5 KBName:  IMG_0045.jpg
  6. 10-18-2018, 11:57 AM
    Reason
    no longer relevant
  7. 10-19-2018, 12:25 PM
    Reason
    no longer relevant
  8. 10-19-2018, 05:22 PM
    Reason
    no longer relevant
  9. #166
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Black plates bolted in back of Van???
    I searched to no avail...
    I am ripping into the little van finally, and removed all the plywood from the cargo floor to find these. Three black plates bolted to the floor. They look factory~ish, not sure what to make of them though... What the heck are they for? Are they important or just a waste of steel?
    1987 Cargo Van 4x4, if it makes a difference.
  10. #167
    Oct 2015
    Walnut Creek, CA
    Re: Black plates bolted in back of Van???
    Ballast I believe. found the same when I was monstalining the interior of my 87 cargo 4wd van
  11. #168
    Aug 2016
    Lakeside, Az.
    Okay that's kind of what I figured...
    I'm yanking them out, I don't think that 60 or 70 lb of Steel is going to make this pig any more stable. Ha...
  12. #169
    Actually this has been asked at twice before: HERE and HERE
    I realize when you don't know what something is called, you can't search for it by name. That's why we have the stickied "WHAT-IS-THIS-PART" threads.
  13. #170
    atlanta
    Part number for 89 driver side window lift motor? I ordered through advance Auto site and it's not even close.
  14. 12-11-2018, 08:33 PM
    Reason
    member says found answer but did not reveal; exhange has no value without answer
  15. #171
    Quote Originally Posted by syn View Post
    Looks like the Toyota P/N is 8572016030.
    When I use the search-by-part-number feature on Rock Auto, a couple of choices do come up. No idea if the Toyota version is discontinued or not; no power windows here ...
  16. 12-11-2018, 09:50 PM
    Reason
  17. 12-11-2018, 09:52 PM
    Reason
  18. 12-11-2018, 11:26 PM
    Reason
  19. 12-11-2018, 11:41 PM
    Reason
  20. 12-12-2018, 12:01 AM
    Reason
  21. 12-12-2018, 12:04 AM
    Reason
  22. #172
    Aug 2016
    Lakeside, Az.
    I have been scouring the electrical system today and have verified all of my plugs, save this one... At the air box portion of harness. two prong plug, one white wire with black stripe and a green wire. I have hunted for the other side of it, but see nothing to connect to. I also have a dangler underneath coming off the Alternator harness and believe it goes to a sensor for oil level (sucker is hard to get at! Would explain my red oil light remaining on. According to the FSM the red dummy light on the oil reads pressure AND level via this plug. Mine is an 87 cargo van , so that trim package/ gauge cluster has no option for the amber "oil level" light. Found the level switch and access is rough! Ha. Everything else electrically is accounted for though!
    Attachment 8122
  23. #173
    The search terms you want are "Fuel Pump Check Connector" and "Circuit Opening Relay" to narrow it down, just put all those words into the search box. Here's a good post to get you started:
    https://www.toyotavantech.com/forum/...=3517#post3517
  24. #174
    Aug 2016
    Lakeside, Az.
    Edit: This is the Old cigarette lighter plug, traced the wiring diagram out in the FSM~ I recently took apart my dash and have ONE unaccouted for plug. I am guessing that it may have been for the factory lighter in the radio/ air mixer bezel??? It has a green (power), gray (ignition), and I think a couple of ground wires in it... The previous owner added an aftermarket cig lighter and connected it to the radio wires.
    Is my assumption right? I looked and couldn't find it...
  25. #175
    '88 4x4 5 speed manual
    Dec 2018
    ME
    4WD L Inner Tie Rod End - Need part #
    My mechanic says I need to replace the L Inner Tie Rod End.
    88' 4WD
    Having trouble locating that part # - anyone got it handy?
    Thanks.
  26. #176
    Aug 2016
    Lakeside, Az.
    Re: 4WD L Inner Tie Rod End - Need part #
    Quote Originally Posted by cpginkpt View Post
    88' 4WD
    Thanks.
    Amazon and Rock Auto is your best friend with these little vans:
    https://www.amazon.com/ACDelco-45A11...ywords=tie+rod
    https://www.rockauto.com/en/catalog/...e+rod+end,7428
    Took me all of 3 minutes to find these dude. Just sayin'...
  27. #177
    Dec 2018
    ME
    ah yes - I was searching for Tie Rod which is listed at Rock, but the correct part 45A1133 did not have the words "tie rod" next to it for some reason.
    Once I crossed reference using your Amazon link (3 month backorder) with correct description then I could find it in Rock.
    Thank you!
  28. #178
    88 4wd
    Apr 2017
    Oakland
    Hoping someone can help me identify what this part in the red circle is? Thank you!
    Name:  Screen Shot 2019-01-14 at 4.18.49 PM.jpg
  29. #179
    Aug 2016
    Lakeside, Az.
    Looiks like the infamous temp. vacuum switch. It is the source of made up curse words, so if it's intact, not broken... Don't touch it. Don't look at it. Leave that one alone!
  30. #180
    88 4wd
    Apr 2017
    Oakland
    Oh boy... guessing by that response these are NLA?
