0-9
000 miles
1st/2nd gen auto tranny comparison
1st/2nd gen body comparison
1st/2nd gen interior comparison
3y engine into 4y van
3Y-EC
3Y/4Y cylinder head comparison
3Y/4Y engine comparison
3Y/4Y radiators compared
4k-c
4WD
4y engine into 3y van
4y forklift engine
4y turbo mod
A
a/c
a/c (add)
a/c (r-12)
a/c (r-134a)
a/c (rear)
a/c belt
a/c charging
a/c compressor
a/c condenser
a/c convert r-12 to r134
a/c evaporator
a/c fuse blowing
a/c idle up vsv
a/c leak
a/c pressure switch
a/c problem front only
a/c system removal
acceleration issue
accelerator pedal
accelerator pedal sticks
aerostar springs
air filter
air flow meter
alignment
alignment scam
alternator
alternator brushes
alternator diodes
alternator harness
alternator noise
alternator overcharging
alternator purchase (denso)
alternator rebuild
alternator regulator
alternator removal
alternator shield
alternator upgrade
alternator upper mounting bracket
alternator wire harness
altimeter
amphibious van
antenna (oem)
anti-seize
assembly lube
auto insurance
auto tranny check ball
auto tranny cooler
auto tranny fluid
auto tranny leak
auto tranny noise
auto tranny pan
auto tranny pump
auto tranny reinstall
auto tranny removal
auto tranny rpm
auto tranny shift solenoid
auto tranny slipping
auto trans a44dl (84-86)
auto trans a45
auto trans a45dl (87-89)
automatic to manual transmission swap
auxiliary air valve
awning
axle
axle (rear)
B
backup lights
backup lights (cargo plus LE)
ball joint replacement
ball joints
ballast
battery
battery (parasitic drain)
battery (second)
battery bad
battery box/carrier
battery cable
battery ground cable
battery monitor
battery negative cable
battery not charging
battery reversed
battery terminals
battery testing
battery warning light
battery warning light off
bearing
belt
belt adjustment
belt broken
bench tester
bike rack
bimetal vacuum switching valve (BVSV)
block heater
body damage
body paint
body parts
body repair
body rust
bolt broken
bolt sizes
bore
bore gauge
bores
bra
brake bleeding
brake booster
brake calipers
brake drum
brake drum springs
brake fluid
brake fluid leaking
brake lights
brake lines and hoses
brake master cylinder
brake pads
brake rotors
brake rotors (removing bolts)
brake warning light
brakes (rear)
brakes drag
brakes lock
brakes not working
brakes soft/spongy
brush guard
bumper
bumper (custom)
bumper removal
bushings
buyer advice
buzzer
C
c4057s
cam
cam gear
camshaft
car insurance
carburator/carburated
cargo barrier
cargo net
cargo/load capacity
catalytic converter
center console
charging problem
charging system
check brake fluid
check coolant
check engine light
check engine light with no code
check fluids
check oil
check power steering fluid
check wiper fluid
christmas dash —> dash warning lights stay oncigarette lighter
circuit opening relay
clean contacts
cleaning engine exterior
cleaning solution disposal
clearance
clock (analog)
clock fuse and circuit
cluster
cluster backlight (oem)
cluster swap
clutch bleeding
clutch chatter/shudder
clutch fluid reservoir
clutch flywheel
clutch hydraulic lines
clutch issue
clutch kit
clutch line
clutch master cylinder
clutch replacement
clutch slave cylinder
clutch start switch
code 10 (86/87)
code 11 (86/87)
code 12 (88/89)
code 14 (88/89)
code 2 (84/85)
code 21 (88/89)
code 22 (88/89)
code 24 (88/89)
code 25 (88/89)
code 25 with code 26 (88/89)
code 26 (88/89)
code 3 (86/87)
code 4 (84/85)
code 4 (86/87)
code 4 with code 11 (86/87)
code 42 (88/89)
code 5 (84/85)
code 5 (86/87)
code 5 doesn't clear
code 51 (88/89)
code 6 (86/87)
code 7 (86/87)
code 71 (88/89)
code 9 (86/87)
codes
codes (how to check / pull)
codes (how to clear)
coil spring spacer
coil springs
coil springs (rear)
cold start injector
cold start injector time switch
collision catalog
compression
compression issue
compression test
condensation inside van
control arm
control arm bushings
convergence of vans
convert 2wd to 4wd
convert to carburator
coolant drain
coolant hoses and pipes
coolant in oil
coolant leak / loss
coolant level
coolant level (radi) warning light
coolant level sensor
coolant level sensor grommet
coolant overflow tank
coolant reservoir is overflowing
coolant type
cooling system
cooling system corrosion
cooling system flush
cooling system mods
cornering light
cornering light relay
crankshaft
crankshaft (sheared key)
crankshaft pulley
crankshaft pulley seal
cruise control
cv axle
cv boot
cv joint
cv joints
cylinder head
cylinder head bolts
cylinder head rear plate
cylinder head rebuild
cylinder head replacement
cylinders
D
dash (cluster) lights / bulbs
dash backlighting
dash lights led upgrade
dash warning lights remain off (some or all)
dashboard disassembly
dashpot
death metal van
deck
dial indicator
diameter
died while driving
diesel 2c engine
diesel 2c head
diesel 2c radiator
diesel 2c-t engine
diesel 2c-t head
diesel 2c-t headgasket
diesel 2c-t radiator
diesel buyer advice
diesel crankcase breather
diesel died while driving
diesel engine oil
diesel engine sourcing
diesel fuel economy
diesel fuel pump
diesel injection pump
diesel intercooler
diesel leak
diesel mechanic
diesel oil filter
diesel overheating
diesel service manual
diesel speed
diesel turbo
diesel — oil in intake
differential
differential (locking)
differential leak
differential limited slip
differential noise
differential oil
differential ratios
differential seal
differential: auto diff with manual tranny
dimensions cargo van
diode
dipstick
distributor
distributor rotor
door handle
door hinges
door lock cylinders
door open circuit
door open sensors
door open warning light
door removal (front)
door seals (aftermarket)
doors
driveline
driveshaft
driveshaft balancing
drivetrain
E
eazy-out
ecu
ecu faulty connection
efi circuit
efi fuse
egr system
electrical (additional feed / tap)
electrical connector
electrical connector pins
electrical problem
electronic parts catalog
emergency brake
emergency brake boot
emergency brake cable
emissions testing (smog)
end gap
end play
engine access
engine backfiring
engine bay insulation
engine bay seal
engine block drain
engine fan and fan clutch (oem)
engine fan (electric upgrade)
engine fan shroud
engine missing
engine noise
engine noise (knocking)
engine noise (pinging)
engine oil
engine oil additives
engine oil capacity
engine oil change
engine oil leak
engine oil low
engine oil metal shavings
engine oil specifications
engine oil use high
engine rattle
engine rear main oil seal
engine rebuild
engine rebuild advice
engine rebuild break-in
engine removal
engine running rough
engine running too cool
engine running warm
engine service connector
engine service hole cover
engine service hole cover latches/clips
engine service hole cover support band
engine service hole sub-cover
engine sourcing (oem)
engine swap (non-oem)
engine swap (OEM)
engine+autotrans removal
estima
ev conversion
exhaust black
exhaust blue
exhaust gasket
exhaust leak
exhaust manifold
exhaust manifold glowing red
exhaust manifold removal
exhaust noise/hum
exhaust pipe
exhaust smelly
exhaust smoke
exhaust system
exhaust white
expander
exterior trim
exterior trim clips
F
feeler gauge
fiber optic cable (ashtray backlight)
fipg
flare
fog lights
frame
freeze plug
fuel breather hose assy
fuel cap
fuel capacity
fuel cut rpm
fuel delivery
fuel door
fuel economy
fuel economy (poor)
fuel filter
fuel gauge
fuel gauge sending unit
fuel injector cleaning
fuel injector connectors
fuel injector pintle
fuel injector wiring
fuel injectors
fuel leak
fuel line
fuel low warning light
fuel mixture running lean
fuel mixture running rich
fuel pressure
fuel pressure regulator
fuel pulsation damper
fuel pump
fuel rail
fuel sender
fuel system
fuel system contamination
fuel system precautions
fuel tank
fuse (am1)
fuse block
fuse block melted
fuse box
fuse chart
fuse(s) blowing
fusible link
fusible link 0.5g
fusible link 1.25b
fusible link 2.0l
G
gap
gas to diesel swap
gauge blocks
gauges (aftermarket)
gear oil
glovebox
gross vehicle weight
H
harmonic balancer
hazard lights
headgasket
headgasket — non-oem
headgasket breach
headgasket replacement
headlight circuit issues
headlight relay
headlight wiring
headlights
headlights (led upgrade)
headlights high beam out
headlights low beam out
headlights out driver side only
headlights out passenger side only
headlights-on warning
heat soak / hot soak
heater core
heater core (rear)
heater core replacement
heater deletion
heater deletion (rear)
heater valve
hesitation
hiace
high top
hood —> engine service hole coverhorn
hood holder —> engine service hole cover support band
hose (air cleaner/intake)
hose of death --> hose — water bypasshose — water bypass
hoses (diy molding)
hvac (rear)
hvac blend door/lever
hvac blower motor
hvac cabin heat
hvac cabin heat rear
hvac cables
hvac control faceplate
hvac control levers
hvac control spider
hvac defrost
hvac filters
hvac no heat
hvac vents / ducts
hydraulic lifters
I
icemaker
identifying parts
idle adjustment
idle issue when cold
idle issues
idle rpm vacuum meter
idle speed
idler pulley bearing
igniter (84/85)
igniter (86-89)
igniter (purchasing)
ignition coil
ignition cylinder
ignition interlock
ignition switch
instrument cluster —> clusterinsurance
insurance value
intake manifold
intake manifold gasket
intake manifold removal
interior (carpet)
interior (dashpad)
interior (headliner)
interior lights
interior lights (courtesy lights)
interior mods
interior mods (camperize)
interior mods (curtains)
interior mods (insulation / sound reduction)
interior mods (rhino liner inside)
interior refurbishing
interior trim
interior trim (door)
J
jack and OEM tire change tool kit
jdm front brake pads
jdm mirror
jdm part numbers
jdm previa
jdm rear brakes
jdm speaker
jdm van
jerking
jump start
junkyard vehicle search
K
key broken
key-way
kick-down cable
kill switch installation
L
ladder
leaf springs
leak above transmission
leak at back of engine
license plate lights
lift
lift (2wd)
lift kit
lift with leaf springs
liftgate
liftgate electrical
liftgate handle
liftgate interior trim
liftgate lock cylinder
liftgate mechanical
liftgate struts
light bulb replacement
liteace
load sensing and proportioning valve (LSPV)
lobe
locate shorts & bad wires
lpg
M
magnaflux
manual (owners)
manual (service)
manual hubs
manual to automatic transmission swap
manual tranny leak
manual tranny rebuild
manual tranny replacement
manual tranny service
manual tranny shift cable
manual transmission
manual transmission: G52
manual transmission: G53
masterace
mechanic requests / recommendations
merchandise
micrometer
mirrors (power side)
mirrors (side)
model f (european van)
molybdenum
motor brushes
motor mounts
mr. gasket
muffler
N
neutral start switch
nissan
noise
noise from dash
noise when shifting
noise when steering
noise — chirping
noise — clunk
noise — squealing
noise — tapping
noise — ticking
noise — whirring
noise — whistling
O
o2 sensor (84-87)
o2 sensor (88-89)
ohmmeters
oil —> engine oiloil cap / cap gasket
oil cooler
oil dipstick
oil drain plug/gasket
oil filter
oil filter gasket
oil level light (le vans)
oil level sensor
oil pan
oil pan gasket
oil pressure
oil pressure / oil level combo light (cargo / DLX)
oil pressure gauge (aftermarket)
oil pressure gauge OEM (LE)
oil pressure sensor
oil pump
oil seal (rear)
oil warning light
oiling problem
options by model and year
overdrive
overdrive (electrical)
overdrive (stuck in overdrive)
overdrive relay
overdrive solenoid
overdrive thermo switch
overheating
overheating alarm
overheating no cabin heat
P
part interchangeability
part numbers
parts source
parts source (oem)
parts to pull
parts — aftermarket
passenger side access panel —> engine service hole sub-coverpcm
pcv
pcv hose
pcv valve
petrol
pin
pinion bearing
piston rings
pistons
plastigauge
plus box
pop top
posting in the forum
power locks
power loss / low
power steering 2nd gen/4y
power steering belt
power steering delete
power steering fluid (ATF)
power steering fluid (ATF) leak
power steering idler pulley
power steering lines and hoses
power steering noise
power steering overfill
power steering pump
power steering pump leak
power steering rack
power steering reservoir
power steering vacuum lines / parts
power windows
previa
propeller
propeller shaft
push bar
R
radi light —> coolant level (radi) warning lightradiator
radiator (84/85)
radiator (86/89)
radiator cap
radiator drain petcock
radiator hose
radiator recore
re-boring block
rear end
rear end noise
rear end swap
remove insulation / glue / adhesives
revive after sitting
right hand drive (RHD)
rims — cleaning chrome
rims — cleaning steel
rims — alternate
rims — oem
rims — painting steel
ring pliers
rocker arm bar
rocker arms
rocker cover gasket
rocker shaft
rod
roller lifters
roof rack
roof vent
rpm
S
safety
sagging back end
scam
scarce parts to pull
scoop
seafoam
seal retainer
sealed power
searching the forum
seat mounting bolts
seat restoration
seatbelt warning relay
seatbelts
seats
seats (front)
seats (jdm)
seats — captain's chairs
seats — reupholster
security system (aftermarket)
service (recommendations)
shift lock
shift lock override
shifter
shifter boot
shifter knob
shifting from D to R (auto tranny)
shifting problem auto tranny
shifting problem manual tranny
shimmy
shims
shocks
shocks (air)
shoulder belts
shudder in reverse
side marker lights
skid plate
slider door
slider door (modification to clear wide tires)
slider door handle
slider door latch
slider door track
smell when under load
smell — burning
smell — burning rubber
smell — exhaust in cabin
smell — gasoline
smell — rotten egg
snorkel
solar power
spacecruiser
spacia
spare tire carrier
spare tire rack (mod)
spark plug tubes
spark plug wires
spark plug — remove broken
spark plugs
spark plugs — oily
speakers
speakers (rear pillar)
speedometer
speedometer cable
springs
sprocket
sputtering
staked / staking
stalling
stalling when angled down
stalls when turning left
stalls/rough when humid
starter
starter contacts
starter rebuild
starter relay
starter replacement
starting problem
starting problem when cold
starting problem when hot
starting problem: click no start
starting problem: clunk no start
starting problem: cranks but no start
starting problem: no click no start
starting problem: no spark
starting problem: no spark no fuel
starting problem: no start and no lights
starting problem: not cranking
starting problem: slow crank
starting problem: spark no fuel
starts won't stay running
steering
steering (84/85)
steering (86-89)
steering column
steering idler/center arm
steering loose
steering problem
steering rack
steering recalls
steering shudder
steering wheel
steering wheel (aftermarket)
steering wheel puller
stereo (aftermarket)
stereo (OEM subwoofer)
stereo (oem)
stolen
structural support beam
stuck or rusted bolts/nuts
stud broken
sunroof
surface
suspension
suspension (aftermarket parts)
suspension (front)
suspension (rubber parts)
suspension air bags
suspension noise
suspension squeaks
sway bar
T
tachometer
tachometer (add oem)
tachometer (aftermarket)
tail light assembly
tail lights
temperature adjustment
temperature gauge
temperature gauge (aftermarket)
temperature rise after shutdown
temperature sender
temperature sensor
theft prevention
thermostat
thermostat deletion
thermostat replacement
throttle body
throttle cable
throttle position sensor (TPS)
thrust
thrust bearing
tie rod ends
tie rods
timing
timing 3y
timing 4y
timing advance 3y
timing advance 4y
timing belt
timing case
timing chain
timing chain case leak
timing cover seal
timing gear
timing issues
timing light
timing mark
timing mark (jumping)
timing set
tire chains/cables
tire pressure
tire size
tire size (non oem rims)
tire wear (abnormal)
tires
tires (snow tires)
top coat
top dead center (TDC)
top end rebuild
torque
torque converter
torque specs
torsion bars
tow bar
tow hitch
towing
towing (tap into wiring)
townace
townace petrol
toyota part numbers
toyota recalls
transmission mounts
travel preparation
trim level or model
turn signal relay
turn signals
U
u-joint
upper control arm
upper control arm bushings
usb port
V
vacuum hose diagram
vacuum hoses
vacuum switching valve (VSV)
vacuum switching valve (VSV) diagram
valve cover
valve cover gasket
valve grind gasket kit
valve lash
valve stem seals
valve train
valves
vans on tv/movie/ad
vibration
vibration front end
video
vin decoder
W
washer (front/windshield)
washer (rear/liftgate)
washer fluid
washer nozzle (front/windshield)
washer pump
water leak
water leaking into cabin
water pump
water pump bolts
water pump leak@bolt
water pump replacement
water tank add
wheel / tire noise
wheel backspace
wheel bearings
wheel bearings (pressed)
wheel bearings (rear)
wheel noise
wheel offset
wheel stud
winch
window (lift gate)
window rain deflector
window regulator
window tinting removal
window trim
windows (aftermarket)
windows (front)
windows (manual to power)
windows (rear fixed)
windows (slider)
windows slow/sluggish
windshield
windshield repair
windshield replacement
windshield trim
wiper (front/windshield)
wiper (rear/liftgate)
wiper motor (front/windshield)
wiper motor (rear/liftgate)
wiper switch arm / assembly
wiring harness repair / build
Z
zerk fitting
