Results 1 to 11 of 11
Thread: rear bumper bracket - need pic please
    '88 4x4 5 speed manual
    Dec 2018
    ME
    building a custom rear bumper but want to use the original bracketing method.
    I read up on the existing posts so am aware there 2 bolts per mount (1 bottom that threads to frame and 1 top that threads to bracket (?), but could not find any pics of the actually brackets.
    Anyone have rear bumper bracket pics so I can recreate similar?
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Re: rear bumper bracket - need pic please
    Attachment 8177
    There ya go. Same on both sides...
    Aug 2016
    Lakeside, Az.
    Another of both brackets
    Attachment 8178
    Van Addict boogieman's Avatar
    abq, nm
    1.5" x 3/16 square tubing works pretty well..cut at steep angle and weld in a captive nut..
    Dec 2018
    ME
    this is PERFECT - thank you!
    Dec 2018
    ME
    any weird sizing going on with that back bolt (into frame)?
    I've tried a few sizes (assume metric) but can't get a good match to the threads in that body frame hole?
    1988 Master Ace Surf 4wd
    Jan 2018
    Northern California
    The mounting bolts are M12X1.25 IIRC.
    Aug 2016
    Lakeside, Az.
    Quote Originally Posted by Duke View Post
    Thats what I just weasured... nothing odd about them. might need to chase the threads with a tap or something, they tend to take a healthy dose of the elements considering where they are. Ace Hardwrare carries new grade 8 ones if I recall.
    Dec 2018
    ME
    got 'em as recommended and they are perfect. There was a bit of gunk in there which is why it felt like the wrong thread size.
    Yes, I have one
    Mar 2019
    Kingman, az.
    (1987 4X4 VAN) THIS MIGHT SEEM LIKE AN ODD QUESTION, BUT DOES ANYBODY HAVE AN EXPLODED VIEW OF THESE BUMPERS? DO THEY JUST BOLT ON WITH A THROUGH
    BOLT THAT GOES ALL THE WAY FROM THE BOTTOM TO THE TOP? (SORRY ABOUT ALL CAPS. MAKES IT EASIER FOR ME TO READ)------------------------- I'LL LIKELY BE ADDING A FRONT JEEP TUBE BUMPER IN FRONT OF THE FRONT BUMPER AND A SWING AWAY TIRE SPARE BUMPER ON THE BACK. BUT FIRST. I NEED TO FIGURE OUT HOW THEY ALL GO ON. I CAN CRAWL UNDER AND UNBOLT STUFF AT RANDOM OR I CAN AVOID REINVENTING THE WHEEL AND ASK THE GUYS WHO HAVE DONE THIS ALREADY. THANKS GUYS AND GIRLS (JUST IN CASE THERE *IS* A GIRL HERE)
    Heres a few photo I took awhile back when I went to snatch up this sweet bumper-
    Upper bolt cover
    Lower bolt cover
    Body bracket
    Bumper bracket
    Slide bumper out
    Bolts and covers
