Results 1 to 4 of 4
Thread: Is there a way to disable the red oil light?
    1986 5 speed
    May 2015
    Central California
    I followed the procedure of unplugging the sensor to test whether it's a false positive. It is.
    It's been on for years now. Is these a way to just stop disconnect the light?
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Re: Is there a way to disable the red oil light?
    Quote Originally Posted by NewVanOwner View Post
    Two ways... pull the bulb from the gauge cluster that illuminates the red light. OR, on the pan sensor just tie the two wires together and complete the circuit...
    You are talking about the level sensor on the pan, no?
    4x4 Cargo
    Mar 2016
    Cedar City, UT
    Sorry to hijack, Does anyone know where to get a connector that works for the oil pan harness? My oil lights been on since I rewired my alternator and I canít find that connector to make a new harness. If all else fails Iíll just make a jumper wire as suggested...
    Space Cruisers - Cruising Across The Galaxy
    Aug 2016
    Lakeside, Az.
    Quote Originally Posted by spacecruisers View Post
    Only place I know of is the Junkyard... You might try to find a similar size one and modify it also... best I got.
