Page 5 of 5 FirstFirst 12345
Results 81 to 93 of 93
Thread: Parting out 87 Van
  1. #81
    2003 Eurovan & 88 Toyota 4x4 Van
    Feb 2019
    California
    Re: Parting out 87 Van
    Do you still have:
    1. Main window and lock control rail on the drivers side door?
    2. My 4x4 has two independent rear middle seats. I need a seat belt receiver. I have the belt, but nothing to click it into on one of my seats. Do you happen to have one or the set?
    3. I am also looking for the plastic wall mounted seat belt cover (it covers the mount bolt) for my rear bench seat.
    MacD
  2. #82
    1986 Toyota Van 2wd
    Jun 2020
    LBC,CA
    Macd, what side for the rear seat belt cover ?
  3. #83
    Feb 2019
    California
    Passenger side.
  4. #84
    1986 LE 2 wd 1988 4x4
    Apr 2016
    Del Norte, Colorado
    How about the quarts clock? Mine went k-putz and shorted. I don't need the trim, just a working clock. Be careful of testing it outside the vehicle. It is polarity sensitive and will short out if hooked up incorrectly. When the clock shorts out, the dome lights won't work and the battery will go dead in a few days. To test the clock for a short, close all the doors & pull the fuse #5 and insert small spade connectors or wires connected to a test light. If it lights up and the clock doesn't, it's bad. Oh... be sure you have the battery connected.
  5. #85
    85 van
    Aug 2020
    Boulder
    In need a of a speedometer cable!
  6. #86
    1989 Wagon, 2WD
    Sep 2020
    Tucson, Arizona
    Looking for the drivers side window regulator. Is this still available? thanks!
  7. #87
    1987 cargo van
    Oct 2020
    La Mesa, California
    Hi there, I realize your post is over a year old, but I have a RWD 87 cargo van which needs the driver's side cornering light and the driver's side amber turn signal/ parking light . Do you still have these?
    Fingers crossed in San Diego County. Thanks, Richard
    trickyrickybaker@hotmail.com
  8. #88
    IG:@dialupthevan 89 - 2WD - 201k 87 - 4WD - 188K
    Feb 2016
    Los Angeles, California
    Quote Originally Posted by RichardBryanBaker View Post
    https://www.ebay.com/itm/NOS-86-89-T...49e4%7Ciid%3A1
    Hope this helps
    That smells like regular! She needs premium DUDE! PREMIUM!
  9. #89
    '87 4-WD 5speed window van wagon
    Jul 2017
    near tomah wisconsin
    i need a passenger side power window regulator (not the motor - just the skeletal part/assembly that holds and guides the window). might it still be available?
    thanks for any response
  10. #90
    1987 Cargo Van 4x4
    Nov 2020
    San Francisco
    Looking for bench seats, available?
  11. #91
    1988 LE 4x4 5 Speed
    Dec 2016
    Tulsa, OK
    I could use a couple of parts if still available. I'm looking for a drivers side front mud flap. Also looking for the LE trim moulding that sits above the right rear wheel.
    Cheers!
  12. #92
    1987 4WD LX
    Nov 2020
    Bellingham, Wa, USA
    Hi erik,
    I am looking for 2 front door hinge pins with the bushings in-tact. Do you have any of those left?
    Thank you
  13. #93
    '92 TownAce 4x4 5spd Cargo Diesel
    Jan 2020
    Brooklyn, Ny
    Hey there!
    Can I get both of the front turn signal lamps??
    Thanks so much!
    Paul
