Results 1 to 3 of 3
Thread: 94 previa has no acceleration and shudders at 50-60 mph
    94 toyota previa
    Jan 2014
    san antonio tx
    have had a loss of power on my 94 non-supercharged previa. acceleration is anemic and when it does finally get up to speed it will sporadicly shudder between 50 and 60mph. engine idle is fairly smooth, not great, but not bad. the vehicle has had the fuel pump replaced,distributor,spark plugs and recently a new catalytic converter and denso oxygen sensors were added. i have cleaned the throttle body and egr valves so those are done. any ideas on what could be causing this? thanks.
    1993 2WD Previa LE
    Jun 2017
    Delaware
    Re: 94 previa has no acceleration and shudders at 50-60 mph
    I had a similar issue with my 93 NA Previa. Have you checked the Air Flow Meter? The service manual has a test procedure that you can use an ohm meter to go through. It could also just be a poor connection on the AFM plug.
    94 toyota previa
    Jan 2014
    san antonio tx
    problem resolved. #3 fuel injector is bad.
