Fan Bracket
I recently replaced the water pump, timing belt and v-belts in my 1988 MasterAce Surf. The cooling fan pulley, which I recently found out is called the fan bracket, is a bit noisy. I was unable to find a replacement or figure out how the bearing comes out. Does anyone know of a source for the fan bracket or how to replace that bearing?
