Results 1 to 3 of 3
Thread: AT OIL TEMP ON 1987 TOYOTA VAN
    1987 toyota van le
    Jul 2019
    nj
    So still working on van. got a new battery and couple of lights turn one is the AT OIL TEMP ON 1987 TOYOTA VAN i cant even find the stick for regular oil or trans oil. what could this be? car was sitting for a year btw. battery lights comes up to and i just put in a new battery. car has been turning on fine these days.
    1987 Toyota 4wd Cargo Van
    Aug 2016
    Lakeside, Az.
    Re: AT OIL TEMP ON 1987 TOYOTA VAN
    You are experiencing the "christmas tree" dash.
    Prolly nothing to do with AT temp and everything to do with your charging system. More than likely the Alternator or one of the fusible links... not uncommon for our vans, and an easy enough fix.
    Grab a multimeter and check your voltage. If it's charging correctly, you should have between 13.25 and 14V, if it isn't start exploring your wiring. Start with the Fusible link that ties to your charge circuit and move your way back to the alt. plug.
    Search will direct you to these things.
    PNW
    HERE is the "how to search TVT and win" stickied thread.
