Results 1 to 18 of 18
Thread: Everything Must Go - Lots of photos
    1987 4wd 5spd
    CA
    Photos here: https://imgur.com/a/gWjB0Xr
    These parts aren't doing me any good taking up space and I don't have a van any more.
    Listings should go with the order of the photos in the album linked above. Prices don't include shipping (probably). Prefer local sale (bay area california mostly), especially for large/heavy items. Willing to ship things though. Buy in bulk and save. Everything is OBO. Paypal for shipped orders, cash in person. Trades considered. Local person will probably get freebies out of me. Will update thread as parts sell. Thanks for looking!
    4WD Original Wheels. 3 have Maxxis Bravo tires, one unmatching tire. All tires hold air but are old, fine for around town probably. No cracks or problems with the wheels, could use some paint if one were inclined.
    >> $140
    Rear hatch window with rubber molding, has heater wires. No cracks, chips, or scratching.
    >> $60
    Igniter, working. Thought I needed it a new one but the problem was actually my coil.
    >> $60
    Y-pipe / down pipe. Not sure exactly what van it fits. Did NOT fit my 1987 4WD 5 speed.
    >> $50
    Heater valve assembly
    >> $10
    Spare tire cage, no significant rust or weakness, includes pins
    >> $20
    OEM fan, can't vouch for the fan clutch in it.
    >> $10
    Fusebox, good condition
    >> $40
    Fusible links
    >> $5
    Fuel filter bracket
    >> $5
    Fuel filter, new but not oem
    >> $5
    4YE cylinder head, I don't know the condition of it, just got it as a spare.
    >> $80
    Intake with throttle body, has the dashpot on it I believe
    >> $60
    Hard lines, FPR?
    >> $5
    Wiring Harness connectors
    >> $5
    2x Plus Boxes. Both have the bolt inside detached, could probably glue it though
    >> $2
    Engine Brackets? I think they were with the head or intake..not sure
    >> $5
    2x cold start injectors, 1x cold start time switch. Tested ok per FSM if I recall correctly.
    >> $10
    VSV part# 90910-12003
    >> $10
    VSV part# 90910-12005
    >> $10
    Pacific? brand VSV
    >> $5
    Automatic 4wd hubs
    >> $10
    1x Original Van Center Cap
    >> $5
    Front 4WD suspension bump stop for UCA, New in package. 48305-30030
    >> $6 (half the price of TPD)
    2x Front Sway bar bushings new in package. 90385-11021
    >> $2
    front under guard for driver side (4wd vans)
    >> $5
    sliding door track plastic trim piece / end cap
    >> $5
    horn button / steering wheel center pad
    >> $5
    Jack holder
    >> $5
    Marker light
    >> $5
    trim pieces that go on interior behind mirrors
    >> $5
    misc trim, plastics, grab handles, etc. oh and a spark plug tube
    >> $5
    rear heater control housing plastic
    >> $5
    metal seat belt cover panel (for front shoulder strap) covered in carpeting
    >> $5
    interior sliding door grab handle
    >> $5
    stereo bezel, no cracks
    >> $20
    interior caps for rear shocks
    Rear hatch handle/exterior bezel, rough shape, but the handle works
    >> $5
    Rear hatch latch, dirty but complete
    >> $5
    rear wiper motor
    >> $10
    original rear 4WD springs
    >> $10
    transfer case shifter lever assembly
    >> $10
    brown 5spd shifter knob, dirty
    >> $3
    2WD Lower radiator shroud, in good shape
    >> $10
    throttle body, coolant line nipples corroded/damaged
    >> $10
    front/nose bumper trim (LE?)
    >> $5
    original upper control arms, ball joints are toast..maybe you can recondition like forum member carbonized has
    >> $10
    driver seat, reupholster candidate (dirty, torn etc). guts and recline mechanism work
    >> $10
    Unidentified plastics (brown). go around engine hump inside under the carpet? i dont know
    >> $5
    3D Printed 4WD efi Emblem
    >> $5
    Bottom steering column plastic housing, brown with some burgundy paint. Small crack on curved lip, one tab broken off. Would still go together with the top housing.
    >> $5
    Chilton manual, cover is in poor shape but not falling off, inside is in good shape. photo here: https://imgur.com/a/OUXgOcA
    >> $10
    1987 4wd 5spd
    CA
    Re: Everything Must Go - Lots of photos
    Take it all for $300..that's about $500 off if you add up all those prices
    FYI, The unidentified plastics go around the base of center row captains chairs to create a latchable storage compartment.
    1987 4wd 5spd
    CA
    ah thank you! I never had those chairs in my van so I had no idea.
    1988 LE
    May 2016
    Ketchum, Idaho
    Pm sent
    1987 4wd 5spd
    CA
    Won't let me edit the original post so I will update with replies..
    Intake Plenum with Throttle Body is sold
    1988 LE 4x4 5 Speed
    Dec 2016
    Tulsa, OK
    I'll take the front nose bumper trim, both VSV's and the cold start injectors.
    Shane
    918.779.9605
    1987 4wd 5spd
    CA
    1x plus box SOLD
    3D Printed 4WD EFI emblem SOLD
    1987 4wd 5spd
    CA
    Sale pending on:
    Center cap
    Fuse box
    Rear hatch latch
    Spare tire cage
    Nose trim
    Cold starts
    VSVs
    Stereo bezel
    Horn button
    Jack holder
    Rear window glass
    Oct 2015
    Walnut Creek, CA
    Are cold start injectors still available? thx Josh
    1987 Toyota Van Wagon
    Jul 2019
    Maryland
    Hi! I need that ignitor module like yesterday. Are you in the San Diego area by chance?
    Give me a call, I can go above what you're asking for it, call me 2402103443
    1987 4wd 5spd
    CA
    Sorry the Cold start injectors are sold
    as are:
    Center cap
    Fuse box
    Rear hatch latch
    Spare tire cage
    Nose trim
    VSVs
    Stereo bezel
    Horn button
    Rear window glass
    However, the igniter is still AVAILABLE.
    1987 5-spd Toyota Van
    Jul 2019
    East Bay Area
    I have an exhaust leak and the previous owner must have used this exhaust system to practice his welding...So i may take that y-pipe off your hands if I need to do a pull exhaust overhaul. I will let you know. Going to the muffler shop today.
    1987 4wd 5spd
    CA
    Quote Originally Posted by MartyVanFly View Post
    Sent you a PM MartyVanFly
    Toyota wagon 1987
    Jan 2019
    Los angeles
    Talking Re: Everything Must Go - Lots of photos
    do you have by any chance the engine for the window of the passenger seat?
    1987 4wd 5spd
    CA
    Quote Originally Posted by Willotquentin View Post
    Sorry, I do not
    1987 4wd 5spd
    CA
    >> $140
    Price reduction: $120 for wheels
    1987 4wd 5spd
    CA
    Wheels are sold
