Photos here: https://imgur.com/a/gWjB0Xr
These parts aren't doing me any good taking up space and I don't have a van any more.
Listings should go with the order of the photos in the album linked above. Prices don't include shipping (probably). Prefer local sale (bay area california mostly), especially for large/heavy items. Willing to ship things though. Buy in bulk and save. Everything is OBO. Paypal for shipped orders, cash in person. Trades considered. Local person will probably get freebies out of me. Will update thread as parts sell. Thanks for looking!
4WD Original Wheels. 3 have Maxxis Bravo tires, one unmatching tire. All tires hold air but are old, fine for around town probably. No cracks or problems with the wheels, could use some paint if one were inclined.
>> $140
Rear hatch window with rubber molding, has heater wires. No cracks, chips, or scratching.
>> $60
Igniter, working. Thought I needed it a new one but the problem was actually my coil.
>> $60
Y-pipe / down pipe. Not sure exactly what van it fits. Did NOT fit my 1987 4WD 5 speed.
>> $50
Heater valve assembly
>> $10
Spare tire cage, no significant rust or weakness, includes pins
>> $20
OEM fan, can't vouch for the fan clutch in it.
>> $10
Fusebox, good condition
>> $40
Fusible links
>> $5
Fuel filter bracket
>> $5
Fuel filter, new but not oem
>> $5
4YE cylinder head, I don't know the condition of it, just got it as a spare.
>> $80
Intake with throttle body, has the dashpot on it I believe
>> $60
Hard lines, FPR?
>> $5
Wiring Harness connectors
>> $5
2x Plus Boxes. Both have the bolt inside detached, could probably glue it though
>> $2
Engine Brackets? I think they were with the head or intake..not sure
>> $5
2x cold start injectors, 1x cold start time switch. Tested ok per FSM if I recall correctly.
>> $10
VSV part# 90910-12003
>> $10
VSV part# 90910-12005
>> $10
Pacific? brand VSV
>> $5
Automatic 4wd hubs
>> $10
1x Original Van Center Cap
>> $5
Front 4WD suspension bump stop for UCA, New in package. 48305-30030
>> $6 (half the price of TPD)
2x Front Sway bar bushings new in package. 90385-11021
>> $2
front under guard for driver side (4wd vans)
>> $5
sliding door track plastic trim piece / end cap
>> $5
horn button / steering wheel center pad
>> $5
Jack holder
>> $5
Marker light
>> $5
trim pieces that go on interior behind mirrors
>> $5
misc trim, plastics, grab handles, etc. oh and a spark plug tube
>> $5
rear heater control housing plastic
>> $5
metal seat belt cover panel (for front shoulder strap) covered in carpeting
>> $5
interior sliding door grab handle
>> $5
stereo bezel, no cracks
>> $20
interior caps for rear shocks
Rear hatch handle/exterior bezel, rough shape, but the handle works
>> $5
Rear hatch latch, dirty but complete
>> $5
rear wiper motor
>> $10
original rear 4WD springs
>> $10
transfer case shifter lever assembly
>> $10
brown 5spd shifter knob, dirty
>> $3
2WD Lower radiator shroud, in good shape
>> $10
throttle body, coolant line nipples corroded/damaged
>> $10
front/nose bumper trim (LE?)
>> $5
original upper control arms, ball joints are toast..maybe you can recondition like forum member carbonized has
>> $10
driver seat, reupholster candidate (dirty, torn etc). guts and recline mechanism work
>> $10
Unidentified plastics (brown). go around engine hump inside under the carpet? i dont know
>> $5
3D Printed 4WD efi Emblem
>> $5
Bottom steering column plastic housing, brown with some burgundy paint. Small crack on curved lip, one tab broken off. Would still go together with the top housing.
>> $5
Chilton manual, cover is in poor shape but not falling off, inside is in good shape. photo here: https://imgur.com/a/OUXgOcA
>> $10
