Results 1 to 6 of 6
Thread: 1988 manual 4wd le, central Florida ($4,000)
    1985 LE auto 300k, 1988 5spd 4wd 140k.
    Jun 2014
    Florida
    Hey, I'm selling a 88 4wd manual le with auto locking hubs. Price $4,000. Engine has 105k original miles, transmission and van have around 150k miles. Clean florida title
    -extremely solid running/ looking van
    - engine runs smooth/transmission shifts smooth.
    -no oil, water or exhaust leaks
    new parts;
    -clutch/throwout & pilot bearing(Aisin) water pump (aisin), fan clutch (Aisin), thermostat (toyota)
    -rear main, trans input seal (both Toyota)
    -injectors, fuel filter, fan/alternater belts, plugs/wires & distributed cap, air intake boot , hose of death
    -replaced exhaust studs with the stronger steel black ones along with new exhaust gasket
    -radiator cleaned and pressure tested
    -gear oil changed in front/rear axel, and transmission
    -original head gasket holding strong
    -instrument cluster swapped ( states 127k) other cluster guages weren't working
    -heater works good, no a/c ( a/c components removed)
    -cruise control not working
    -14' spare tire and holder
    -van has 15"rims w/ big size tires ( no wheel well mods or lifts so these tires are currently not road worthy( scraping front wheel well) tread is good yet 2 have some dry rot
    -van has always been ran with 14"rims
    -interior is good besides the carpet has staining
    -dash not cracked
    -little rust around rear hatch window and starting to form on exterior slider
    -overall a very solid body on the van.
    -small 1inch windshield crack on the bottom center,
    -no water leaks inside windshield
    - have bench back seats with seat belts (both red seats or grey rear and blue center bench)
    this van is road ready minus the oversized tire situation, leaveing the sledge hammer option to the next owner! happy to answer any questions-
    Last edited by austinfromflorida; 09-22-2019 at 04:57 PM. Reason: Adding pics, didn't want to lose my write up
    1987 4WD Automatic
    Sep 2010
    On the outskirts of Mordor
    Re: 1988 manual 4wd le, central Florida ($4,000)
    Nice van Austin!
    I really like the Rhino-Liner bottom coverage. Nice contrast with the silver paint job.
    I just realized the Rhino-Liner conveniently takes care of the pesky (missing?) LE trim. That's a good trick!
    Jun 2014
    Florida
    Thanks, I do have a complete set of le trim on a parts van that can go with the purchase if anyone wants to revert it back to its roots.
    Quote Originally Posted by trestlehed View Post
    Nice van Austin!
    Apr 2015
    wherethevanisrare. FL
    Did you get my PM?
    LG.
    1988 LE
    May 2016
    Ketchum, Idaho
    Tried to PM, box is full. Very interested in vermont.
    Jun 2014
    Florida
    Inbox is cleared.
    Quote Originally Posted by whatvan View Post
