Results 1 to 4 of 4
Thread: Brake hardware/pad support plates
    '94 Previa LE
    Dec 2018
    Virginia
    On my '94 Previa (ABS and disc brakes all around), on the front brakes I have the pad support plates installed differently on passenger side from the driver side. One side has the outer pad support plate clip tucked in between the caliper carrier and the pad keeping tension on the pad, the other side has this clip coming outside of where the pad runs on the caliper carrier and instead ends up springing out halfway down the pad. Does anyone have a picture of the proper placement of these pad support plates? The FSM doesn't seem to say and I'm not 100% which way is the correct way. I attached a photo below of the way I believe these pad support plates should be installed.
    '94 Previa LE
    Dec 2018
    Virginia
    Re: Brake hardware/pad support plates
    Okay, I decided to tuck that brake support plate back in between caliber carrier and the brake pad. Was this question too dumb or was nobody willing to glance at their own brakes?
    89' TownAce Auto 87' 4x4 5spd LE 87’ 4x4 5spd Cargo
    SEATTLE, WA
    The question isnít dumb, some may not have a Previa, some may not know the answer, some may not work on our own vans... and some members may not login on a daily basis... ya know...
    Donít be disappointed.
    1992 Previa AT LE
    Feb 2015
    Connecticut
    The placement of these support plates confuse me every time I do a brake job, and speaking of dumb, this is probably the reason THIS happened to me when I didn't install them correctly - my pad drifted to the outside of the rotor and developed a "lip."
    Name:  Pad miswear.jpg
    Here's the proper placement:
    Name:  Proper support plate  placement.jpg
